Post by northernmonkey on Jan 20, 2021 15:00:29 GMT 1
about to start putting my hybrid back to together,its a non tie bar frame any need for them, I will be having pipes made and frame bracing will it make much difference only a road bike running a 400 ypvs motor any advice,cheers
Post by shaunthe2nd on Jan 20, 2021 15:09:49 GMT 1
Tie bars were added because of problems with engine vibration cracking the stock exhausts. They beefed up the exhaust flanges at same time.
If you are running aftermarket exhausts you will be ok, but for stock pipes you may want to think about adding the tie bars.
Post by julianboolean on Jan 20, 2021 15:48:09 GMT 1
Non tie bar bikes crack the exhausts, my first 250 did this.
Post by jon on Jan 20, 2021 18:20:32 GMT 1
I would seriously advise adding tie bar brackets if your crankcases have the bosses for them, if you intend to paint/powder the frame.
If not as said with aftermarket expansions you probably won’t have a problem.
Post by 123 on Jan 20, 2021 18:50:32 GMT 1
Add tie bars or the engine will move around in the frame in my opinon
N.Robo
Post by N.Robo on Jan 20, 2021 20:04:04 GMT 1
Hi all does anyone do the frame brackets so you can fit tie bars as i would be interested in some if so..
Post by rigga on Jan 20, 2021 20:58:55 GMT 1
No tie bar brackets on mine, Gibson exhausts, and as pointed out by others, not an issue with non standard pipes.
Post by 4l04ever on Jan 20, 2021 23:19:10 GMT 1
If you watch a bike with no tie bars on the dyno you will see the engine moving a lot! Definitely worth fitting the tie bars. I am just adding them to my current bike before fitting a YPVS engine.
N.Robo
Post by N.Robo on Jan 21, 2021 0:19:01 GMT 1
Yes 4lO4ever ive noticed this movement years ago so i would like to fit these before i re powdercoat my frame so wanting the welded on tiebar frame brackets if anyone nos where i can get some or if anyone has a frame cutting with these on thanks.
Post by Tobyjugs on Jan 21, 2021 10:33:40 GMT 1
I have also noticed small engine movement due to the two long bolts engine bolts not being tight enough. I think this is an area most people tend to be lax in. Use a torque wrench for these 2 bolts and nuts.
Post by julianboolean on Jan 21, 2021 11:46:04 GMT 1
I can't say I noticed any difference to ride between a tie bar and non tie bar LC, the exhausts only crack if they're one piece like the standard pipes, I had a non tie bar 350 with Microns for 2 years with no problems and it was the only transport I had at the time.
Post by ajh on Jan 21, 2021 20:53:16 GMT 1
Yes 4lO4ever ive noticed this movement years ago so i would like to fit these before i re powdercoat my frame so wanting the welded on tiebar frame brackets if anyone nos where i can get some or if anyone has a frame cutting with these on thanks. You could try getting them made. I spoke to a welder/fabricator I just used (thanks to Dusty for the intro), showed him pictures of the tiebars on a mates bike and he said he'd have no problem fabricating the tiebar brackets on the frame when I get round to doing it. BTW There were improvements made to std pipes to stop the cracking on pre tiebar bikes, Im running the later reinforced standard pipes with no tiebars at the mo without problems
Post by stusco on Jan 21, 2021 21:10:46 GMT 1
If you can add them why not
