Post by Woodentop on Jan 20, 2021 11:10:36 GMT 1
Hi,
Probably a new one for this group, but how easy is it to change N1 clocks from MPH to KPH? I live in Norway and don't really need the MPH. Is it just a matter of changing the backing on the clocks? Cheers.
Post by midlifecrisisrd on Jan 20, 2021 11:19:23 GMT 1
You can just change the face and the speed will be in kph but the distance will be in miles
A swap with someone would be the easiest
Think I have a kmh one but face is probably faded
If you want I'll have a look
Post by shaunthe2nd on Jan 20, 2021 12:15:02 GMT 1
As above, I'm sure you would get offers to swap your mph for km set if you posted up an advert. This will mean you don't have to open up the speedo.
If you decide to convert, you can buy facia overlays or replacement facias so that the speed reads correct, but as Steve says that would still mean the odometer and trip is still reading in miles. You can change 2 gears within the clock mechanism to convert these to km's. Its a bit tricky but can be done. I have several spare gears for this as have converted many clocks the other way kms to mph, so if you want a set of km gears FOC, just cover the post, then PM me your address and will get some posted out to you.
Cheers, Shaun.
Post by Woodentop on Jan 20, 2021 13:21:34 GMT 1
The clocks in question are N1 clocks grafted onto a LC2 as the bike didn't have the correct LC2 arrangement when I bought the bike and I prefer the look. How dificult is it to change the gears in the clocks?
Post by jonw on Jan 20, 2021 13:22:56 GMT 1
Im sure you could swap a clock with someone, or sell yours and buy the one you need. The uk hoovers up Mph clocks like mad and prices of mph units are crazy, KMH units are cheap and more plentiful I would think.
Post by shaunthe2nd on Jan 20, 2021 13:26:13 GMT 1
Steve midlifecrisis did a thread on converting earlier LC clocks Kms to mph and principle will be same for your clocks. If you do a search you should be able to find it as it's quite useful and will give you an idea what is required.
Post by midlifecrisisrd on Jan 20, 2021 13:33:38 GMT 1
Post by Chewie01 on Jan 20, 2021 13:40:57 GMT 1
I have a good condition F2 kph speedo that I could do a swap with you if no one else in more need comes along. Ian
Post by midlifecrisisrd on Jan 20, 2021 14:17:48 GMT 1
I could certainly find one, must have some in a box
Post by 123 on Jan 20, 2021 19:33:37 GMT 1
I should have a set i have a look tomorrow
Post by Woodentop on Jan 21, 2021 8:28:45 GMT 1
Hi, I've has a look at the thread about changing the gears and it seems a bit of a hassle. As so many have spare KPH clocks lying around I think this is the best way. If those that have kph clocks send me a PM with an email address and pics of their clocks I can send a picture back of my clocks before they decide. Just to be clear these are N1/F1 clocks.
Post by midlifecrisisrd on Jan 21, 2021 9:44:45 GMT 1
You seem to have a couple of offers so I will back out
Post by Woodentop on Jan 21, 2021 10:22:39 GMT 1
Can someone confirm that the N1/F1 kph clocks are the same on the N2/F2?
Post by midlifecrisisrd on Jan 21, 2021 10:35:32 GMT 1
Yes, the actual instruments are the same
Post by cb250g5 on Jan 21, 2021 13:22:27 GMT 1
I have a white faced, red writing KMH speedo if any one needs it.
