Post by thumper500 on Jan 19, 2021 15:17:18 GMT 1
Hi, Can I replace the powervalves seals just taking off one barrel. I have a 350 Ypvs 1985. Thanks Dave
Post by midlifecrisisrd on Jan 19, 2021 15:25:11 GMT 1
Yes but personally I'd want to replace both base gaskets to ensure they are the correct thickness
Its only one extra gasket
Oh and torque the head bolts before the base nuts
Post by thumper500 on Jan 19, 2021 17:21:58 GMT 1
Ok thanks 😊
Post by brg1200 on Jan 20, 2021 2:27:34 GMT 1
Oh and torque the head bolts before the base nuts Steve What’s the logic for that? Just asking for info.
Post by tacky1 on Jan 20, 2021 2:33:35 GMT 1
prevents water leaks, sometimes the head gasket leaks, Best to hand tighten the base nuts, then torque the head and then tighten the base nuts,, Gets the head perfectly seated to the cylinders.
Post by bare on Jan 20, 2021 2:44:09 GMT 1
[/quote]What’s the logic for that? Just asking for info.[/quote] Cylinders are sometimes not parallel or even same length between top and bottom Surfaces. Although if more than barely different.. it will leak Far more dangerously from the bottom /base gasket :-)
Post by midlifecrisisrd on Jan 20, 2021 9:37:50 GMT 1
As above
Head gasket is metal and unforgiving
Base gaskets compress 0.1mm on tightening
Base will take up any tiny differences
