Post by 4ce on Jan 3, 2021 21:37:34 GMT 1
Hi All hope you are all well. I,m building an LC bitsa. It has F2 brake master cylinder and brake calipers. Do I order LC or F2 brake lines? it has an LC splitter. They may be all the same but thought i`d ask here first.
Post by JonW on Jan 3, 2021 22:53:50 GMT 1
Splitters are the same.
If you have F2 forks and calipers then the lower lines would be F2. If you use F2 bars then the top line will be F2. If you use LC bars then the top will need to be LC.
The issue is the clip ons are lower than the straight bars and so the F2 line is shorter.
Post by 4ce on Jan 3, 2021 23:12:59 GMT 1
Thank you Jon
