Post by carioca656 on Jan 11, 2021 13:15:30 GMT 1
hi im using exactly the same frame i thought it had been in a accident at some time no reason for r/h side rail to bend inwards i might use a yzf swing arm giving more clearance
adie
Post by 4l04ever on Jan 11, 2021 18:29:26 GMT 1
I think the later RD frames don't have the weird bend in the one rear rail, so making it harder using the R5 frame...
Post by 123 on Jan 11, 2021 19:24:01 GMT 1
Brilliant work and a brilliant loft
Post by veg on Jan 15, 2021 18:04:37 GMT 1
God hadn’t been in here for a while welcome to the tz top end club rob. You still got those intake gaskets? Why 375 to 350? I’ve gone 34 mm not 36 to make it slightly more practical. I’ve got some spare coolant hose blanking bolts somewhere if you want from memory they are pretty unique size wise. Also got some spare coolant hose I ran flexible core hose that’s reinforced from the pump to the head if you use 4lo bottom end. If you need give me a shout as I may have a spare part or two, or failing that I’ll tell you where I got mine. Ps got your intake rubbers yet? Good luck 👍
Post by veg on Jan 15, 2021 18:06:11 GMT 1
Oh and I’ll be selling my ex Yamaha France pipes as I really need to get some of Dave’s but they are Uber top endy.
Post by 4l04ever on Jan 16, 2021 1:39:15 GMT 1
Hi Veg
Will have a look for the TZ gaskets. If you need any, just let me know and I can pop some nice replicas in the post ;-)
Not sorted intakes, but may make some hybrid YPVS/Vforce/TZ thing yet...
I do have some TZ pipes, but not sure what brand they are .... or where I have put them!
Post by 4l04ever on Jan 16, 2021 17:45:46 GMT 1
Post by sidney81 on Jan 16, 2021 20:35:33 GMT 1
great work .chris
Post by 4l04ever on Jan 16, 2021 21:41:39 GMT 1
It was a joint effort. I marked up where to cut and Simon cut it and welded it :-)
Had to space the seat back away from the tank, as there was no ball room.
Post by veg on Jan 16, 2021 22:48:23 GMT 1
Proper old school love it rob. Going for fully faired or not?
Post by 4l04ever on Jan 16, 2021 22:56:20 GMT 1
May put fairing mounts on the frame, but not fitting one initially.
Post by 4l04ever on Jan 19, 2021 13:16:07 GMT 1
TZ750 top end now with Fahron Engineering for new liners. Going to 66mm.
Post by 4l04ever on Jan 23, 2021 17:41:46 GMT 1
Got it up on some test wheels. just trying to work out where the top shock mount should go.
Post by carioca656 on Jan 23, 2021 19:28:33 GMT 1
Post by midlifecrisisrd on Jan 24, 2021 11:34:12 GMT 1
Pics for Rob
Post by 4l04ever on Jan 30, 2021 20:36:49 GMT 1
Top shock mount fabricated from 60mm square tube cut into a few pieces.
2taol
Post by 2taol on Jan 31, 2021 10:09:56 GMT 1
this is going to be a popular build, everyone loves "TZ" builds
Post by midlifecrisisrd on Jan 31, 2021 13:04:02 GMT 1
Post by 4l04ever on Jan 31, 2021 13:23:53 GMT 1
Trying a photo through google...
Post by 4l04ever on Jan 31, 2021 13:30:18 GMT 1
Coil mounts
Post by sidney81 on Feb 2, 2021 11:11:09 GMT 1
Your cracking on ,like the shock mount 😎
Post by dusty350 on Feb 2, 2021 11:22:36 GMT 1
Looking good Rob🙂 Does your tank clear the shock mount ? I had to trim mine right back. Yours looks further back than mine though so maybe that gives you clearance ? Great progress !
Dusty🙂
Post by 4l04ever on Feb 2, 2021 12:00:23 GMT 1
Mount clears tank by about 10mm. My tank has a big groove up the middle underneath. It must have been for a TZ350 with the long monoshock.
Post by 4l04ever on Feb 2, 2021 12:01:42 GMT 1
My shock mount was based on an LC one, so is not adjustable but my shock is
Post by dusty350 on Feb 2, 2021 13:16:02 GMT 1
Thats good then Rob👍 Its only when I had a close look with the tank fitted on mine that I realised the weight of fuel would make the contact worst. There were witness marks on the tank underside too, but the grinder was employed and I now have clearance ! Look forward to your progress😉
Dusty🙂
Post by 4l04ever on Feb 7, 2021 22:46:03 GMT 1
Fitted coils. Also took a pic under tank to show clearance.
Post by JonW on Feb 8, 2021 0:27:21 GMT 1
Great progress and loving the shock mount. nice work!
Post by 4l04ever on Feb 20, 2021 20:36:33 GMT 1
Cut the last brace from bottom frame rails.
Post by 4l04ever on Feb 20, 2021 20:37:46 GMT 1
Test fitted engine...and exhausts.
Post by 4l04ever on Feb 28, 2021 11:54:52 GMT 1
Next missions are radiator, modifying the seat to fill the gap, and footpeg hangers.
Radiator is a little tricky, as want orginalish, but I prefer more than standard cooling, but need to fit under standard fairing.
