kri101
Seatlock
Dec 30, 2020 17:36:47 GMT 1
via mobile
Post by kri101 on Dec 30, 2020 17:36:47 GMT 1
Hi anyone know how to get the seat lock out,I've dismantled it to the point where just the lock is left in. There appears to be a circlip of some type that I have pushed out as far as I can but without forcing it out and damaging it I'm stuck. I don't have a key and I'm assuming it's in the open position cause the catch moves. Also is it possible to get replacement locks. If the answers no then I need not go any further anyway.
Post by Shytalk on Dec 30, 2020 17:43:26 GMT 1
I think the circlip is spring loaded and you need to get a screwdriver on it and release it,it should only go one way, the lock assembly / body should then push outwards. You can get replacement locks or adjust the tumblers to make a different key work.
