Post by roblc350 on Dec 30, 2020 17:18:47 GMT 1
Any thoughts on getting bad creases out of decals ( already applied to a Tank )
did think of a scalpel & maybe a bit of gentle heat
Failing that cutting out the creased part & replacing just that bit
Any Thoughts
Cheers
Post by shaunthe2nd on Dec 30, 2020 17:29:14 GMT 1
Cut and shut will look like a dogs dinner Unless they only just fitted only way is to remove completely and start again with new. Better still go to somewhere like Image Works who supply and fit. It's a lot harder to do well than people think.
Post by roblc350 on Dec 30, 2020 18:16:52 GMT 1
il second that its a lot harder than people think especially when trying to wrap round double curves as on the F2 Tank
Post by tony2stroke on Dec 30, 2020 19:01:31 GMT 1
Its hard to put right once done, but your best hope is to use a heat gun and warm it up, then peel back to the crease, then heat that bit of the decal you just peeled back to hopefully return the memory of the decal, then stick it back down, this is not easy, and you can destroy the decal trying, too much or not enough heat, but if you have nothing to loose as in this case I would give it a go.
Post by LC_BOTT on Dec 30, 2020 22:17:37 GMT 1
As above, a bit of heat will/should make them shrink a little. Too much and they will disappear into a shrivelled mess
Post by midlifecrisisrd on Dec 30, 2020 22:22:26 GMT 1
I've only done an f2 tank once
Was a right bitch. Did them with soapy water and they took a LOT of manipulation
