Post by mak595 on Dec 20, 2020 14:23:10 GMT 1
Just got the bike together and I can smell fuel in the garage, had a look and there's a drip from one of the lower studs, any pointers? Thinking maybe fuel tap passing?
Post by yamman1066 on Dec 20, 2020 14:31:18 GMT 1
carbs leaking
Post by 4l04ever on Dec 20, 2020 14:35:01 GMT 1
Yes, carbs... dripping on to the top of the engine then running down through the drain hole and dripping off the studs.
Post by mak595 on Dec 20, 2020 14:35:48 GMT 1
I've rebuilt the carbs with new float plungers etc but got to be getting in somehow, when I get a chance this afternoon, I'll check fuel tap initially, perhaps a combination of both....
Post by midlifecrisisrd on Dec 20, 2020 14:39:30 GMT 1
Check the bottom edge of the reed valve gaskets
If it's been overflowing fuel into the cases it can weep through the gaskets
Post by arrow on Dec 20, 2020 15:15:17 GMT 1
You should be able to leave the fuel tap on, all the time if the float valves are working properly. To maintain the correct fuel height in the carbs the valves must seal efficiently.
ajh
Post by ajh on Dec 20, 2020 15:54:31 GMT 1
Quite common, Ive got 3 old yams and all 3 have had drips from the carbs when left standing for weeks. Even though I run them dry. It demonstrated the needle valves werent sealing but also all 3 fuel taps also leaked over time to fill the float bowls. I fixed the taps and didnt bother with the carbs yet
Post by mak595 on Dec 20, 2020 16:53:02 GMT 1
Just had a look and the tap is ok, no fuel coming out, both the carbs seem to be leaking from the float bowl gaskets, strange since there new as well.....
Can't remember where I got the kit from now, had them a while
Post by midlifecrisisrd on Dec 20, 2020 16:59:24 GMT 1
The float gaskets compress
Best to tighten the screws then leave 24 hours as you will find you can tighten the screws more
Post by mak595 on Dec 20, 2020 17:07:04 GMT 1
Ordered a pair of new kits off Norbo to be sure. Cheers guys
Post by mak595 on Dec 20, 2020 17:11:15 GMT 1
Thinking about it, I used new Allen bolt screws and normal washers, do they need a spring washer as well?
Post by midlifecrisisrd on Dec 20, 2020 17:13:52 GMT 1
Originals have spring washers but won't cause your problem
I'd just have nipped them up 😁
Post by mak595 on Dec 20, 2020 17:15:49 GMT 1
dezcbr
Post by dezcbr on Dec 20, 2020 23:11:44 GMT 1
Post by wallcraft on Dec 21, 2020 8:51:30 GMT 1
Are they M4 or M5 size ? Thanks.
dezcbr
Post by dezcbr on Dec 21, 2020 9:45:41 GMT 1
Are they M4 or M5 size ? Thanks. They are M4
Post by mak595 on Dec 21, 2020 10:29:41 GMT 1
Thanks mate, ordered new screws off norbo as well as the gaskets so should be sorted once fitted
Post by 4l04ever on Dec 21, 2020 11:55:57 GMT 1
I always fit the YPVS needle valve repair kits as the tip is rubber coated, rather than metal.
If you need some of my gaskets, can send you some straight out in the post today. Mine are a perfect fit for LC/YPVS carbs.
Cheers
