Post by headcoats on Dec 18, 2020 16:06:31 GMT 1
Post by steeley on Dec 18, 2020 18:01:20 GMT 1
Post by headcoats on Dec 19, 2020 13:33:28 GMT 1
You can buy the needle bearings easily enough , but I need all the sleeves and spacers as my swingarm has nothing with it
Post by LC_BOTT on Dec 19, 2020 14:26:06 GMT 1
Lot of expense involed finding that lot, could you replace them all with simple bearings down to the correct sized pivot? I know these are high load bearings originally, but my JMC arm only has taper rollers fitted each side.
Post by steeley on Dec 19, 2020 18:07:24 GMT 1
Ah , oh dear . you have looked up the price of the sleeves from Suzuki yes .
Post by JonW on Dec 20, 2020 13:13:02 GMT 1
The used sleeves are often trashed and worn. I bought some 'mint used' ones a few years back and they turned up with ghosted roller bearing rollers on em. sigh...
Just buy new ones.
Post by headcoats on Dec 20, 2020 14:43:30 GMT 1
The sleeves then need sleeving to accept the standard LC swingarm bolts too ?
Just trying to figure out the bits I need as I have blinked and forgot the last one I did
needle bearings end caps shims centre tube sleeves standard NK racing reducer sleeves
Is this correct ?
www.rgv250.fr/Files/Other/RGV250_Part_list_VJ22.pdf
Page 68 of 76
Post by midlifecrisisrd on Dec 20, 2020 15:45:33 GMT 1
Don't think you need the shims under the end caps
I know you bin them on a ypvs and don't imagine NK narrows the arm any more than absolutely needed
Post by midlifecrisisrd on Dec 20, 2020 15:46:26 GMT 1
In fact when the arm is converted does he not reduce the centre tube as well
Post by headcoats on Dec 20, 2020 15:51:58 GMT 1
Yes I did it on my other bike I may have the tube, nerf to check but havent the pivot sleeves or thrust washers and needle bearings
Wonder if Metmachex could do some sort of conversion to make the RGV arm to fit an LC
Post by headcoats on Dec 20, 2020 17:29:01 GMT 1
Post by loctite on Dec 20, 2020 19:59:35 GMT 1
Post by headcoats on Dec 20, 2020 20:07:04 GMT 1
Post by loctite on Dec 20, 2020 20:27:50 GMT 1
headcoats wait until tomorrow i will get you the sizes and some pics,
Post by headcoats on Dec 20, 2020 20:32:18 GMT 1
Top Banana !
Post by JonW on Dec 20, 2020 23:39:30 GMT 1
I covered fitting one of these and all the bits on my 421 build in the 'chassis' section of my site. might be worth a look as it has some pics and info. also has the plan to DL which also covers what is needed like the new inner sleeves etc very similar to the nk kit.
Post by headcoats on Jun 13, 2022 16:21:07 GMT 1
Back on this monkey on my back and no further forward LOL
On the success of finding the light plastics , this fecker needs a lamping !
