Post by midlifecrisisrd on Feb 16, 2021 18:43:08 GMT 1
What's wrong with original gear shift shaft? Is the banshee part a direct replacement? They tend to get a groove worn in them where the oil seal lip sits so they leak oil The new superseded shaft is a direct replacement. Only differences are that the recessed section at the splines does not go all the round so the gear change arm will only go on in the one position (the correct position) It's a banshee one so same length as a YPVS one, slightly longer than LC but causes no issues Steve
Post by dusty350 on Feb 16, 2021 18:45:04 GMT 1
It's the same part from Lc through to F2 Pv. It now has a superceded part number but was originally 4l0 18101 00. Dusty
