Post by lc350pete on Nov 17, 2020 19:50:58 GMT 1
Just about to start putting it all back together, picked up the frame and bits and pieces from the powdercoaters today Will be in the classic white and red Bound to have lots of questions ๐ณ
Post by shaunthe2nd on Nov 17, 2020 23:10:53 GMT 1
Looking forward to this. I assume you have sorted most the other components/sub-assemblies/
Putting them together is the most satisfying bit in my opinion.
Good luck with it, I will be looking on with interest as I'm doing something similar but still working myself through lots of bits.
Post by lc350pete on Nov 17, 2020 23:42:14 GMT 1
๐๐ Most of it is using my current bike that Iโve had a long time that needed a lot of jobs doing, things like the forks needed rebuilding Tank was rusty inside and petseal lining had broken up side panels were starting to crack Getting the tank repaired and have spare bodywork luckily in decent condition just needs painting I got another frame on nova a USA import and got it coated in the right colour going to build the bike into that Had all the metal parts powder coated The engine doesnโt need any work as I completely rebuilt it a few years ago and is still good Will replace the reeds though they are carbon ones still ok but donโt want to chance it and have stripped the carbs So lots to do but will post on here regular updates
Post by lc350pete on Nov 18, 2020 14:37:20 GMT 1
Now a rolling chassis ๐
Post by lc350pete on Nov 22, 2020 11:07:47 GMT 1
Post by lc350pete on Nov 22, 2020 11:08:54 GMT 1
Clocks before and after with the excellent ignition surround that Alan made
Post by lc350pete on Nov 22, 2020 11:09:28 GMT 1
Post by lc350pete on Nov 22, 2020 11:10:32 GMT 1
Brake calipers before and after, back from the powder coaters
Post by lc350pete on Nov 22, 2020 11:15:32 GMT 1
Engine is in as well very happy with how itโs going ๐ Just realised that I should strip the front and rear brake master cylinders as well and replace the seals etc inside and order caliper pistons , will have to wait though Iโve spent too much already ๐ But have plenty to get on with ๐
Post by yamark on Nov 22, 2020 20:50:33 GMT 1
Great work, the clocks look factory fresh. Following with interest.
Cheers, Mark
Post by lc350pete on Nov 22, 2020 23:23:58 GMT 1
Cheers, Mark Thanks Mark was a bit nervous cutting off the broken part of the clocks around the ignition switch in case it cracked but it went ok ๐
Post by lc350pete on Nov 22, 2020 23:32:51 GMT 1
Everything has gone well so far but it did struggle a bit with repairing the wiring loom Itโs mostly ok but a couple of the wires were just twisted together and a few joints didnโt look too clever I struggled to solder a couple of the joints as the copper was black I cut it back as much as I could and finally managed to solder it Itโs decent now I did notice new looms available on eBay but pretty expensive
2taol
Post by 2taol on Nov 23, 2020 8:38:22 GMT 1
yea the old looms can suffer from corrosion particularly the black negative wires.
Bike is coming along nicely though.
Post by lc350pete on Dec 3, 2020 12:04:56 GMT 1
New reeds fitted and wiring loom sorted Next job fit and setup carbs ๐๐
Post by lc350pete on Dec 8, 2020 16:26:00 GMT 1
Coming along nicely mainly just bodywork and tank to sort out now Brakes were easier than I expected hardest job was putting on the top fork nuts/caps was a bugger of a job compressing the spring and getting the nut screwed on ๐ณ
Post by lc350pete on Dec 18, 2020 16:54:31 GMT 1
Tank back from Hartlepool has been repaired and relined, it was in a bad way but they did a decent job Next job after Christmas is to get the tank and bodywork painted These are the panels Iโve got bought them nearly 20 years ago donโt know what possessed someone to paint them badly in purple ๐ณ but they are in excellent condition
Post by lc350pete on Dec 22, 2020 0:20:10 GMT 1
Started it up today it ran spot on am so pleased, Iโd stripped and cleaned he carbs runs so much better now, Iโve just got to adjust down the tickover a bit Next job is too cut down the fibreglass belly pan underneath where itโs close to the pipes
Post by donkeychomp on Dec 22, 2020 22:54:40 GMT 1
Nice work Pete, keep it up mate.
Post by shaunthe2nd on Dec 22, 2020 23:13:05 GMT 1
Seem to be progressing well. Once electrics are sorted, and bike running your next big job is the paintwork, that will make a diference. Maybe keep the purple? Lol
Post by lc350pete on Dec 22, 2020 23:37:19 GMT 1
Nice work Pete, keep it up mate. Alex Thanks Alex really happy how itโs going ๐๐
Post by lc350pete on Dec 22, 2020 23:42:37 GMT 1
Seem to be progressing well. Once electrics are sorted, and bike running your next big job is the paintwork, that will make a diference. Maybe keep the purple? Lol Thanks Shaun itโs pretty much sorted now except the bodywork and a few small things yep bodywork is the next big job going to have a go at cutting out the underneath part of a pattern fibreglass bellypan tomorrow going to cut away the area underneath thatโs close to the pipes so that the pipes donโt melt the paint purple paint noooo ๐ณ๐ณ๐๐๐๐
Post by lc350pete on Dec 23, 2020 17:18:52 GMT 1
Pattern fibreglass bellypan before and after cutting away to give clearance for Allspeeds doesnโt look quite right in the photo off the bike but looks good on the bike Just needs painting along with the rest of the bodywork and tank ๐๐
Post by lc350pete on Jan 28, 2021 0:49:04 GMT 1
Still keeping busy on the 31K passed the MOT pleased with that means I can send off the form to the DVLA for age related registration, getting there just got to sort out the bodywork next Have got a problem with the ignition though, very weak spark Iโve tested the coil , canโt get a resistance reading on the HT side so itโs probably buggered , Iโve ordered a banshee set of coils and new plugs from Norbo ๐
Post by stusco on Jan 28, 2021 8:40:27 GMT 1
Money money money Thereโs always something needing bought ๐ฌ
Post by lc350pete on Jan 28, 2021 9:19:19 GMT 1
Money money money Thereโs always something needing bought ๐ฌ Very true there ๐ณ
Post by shaunthe2nd on Jan 28, 2021 9:20:13 GMT 1
Hope you get that spark sorted as its coming along nice.
Post by lc350pete on Jan 28, 2021 11:53:34 GMT 1
Hope you get that spark sorted as its coming along nice. Thanks ๐ Iโm hoping itโs the coil not the CDI glad it got through the MOT ok though and really pleased how itโs going next stage is applying for age related number
Post by lc350pete on Jan 29, 2021 23:17:16 GMT 1
Spark sorted a nice fat spark with the banshee coils ๐๐
Post by lc350pete on Feb 26, 2021 13:00:45 GMT 1
Logbook arrived today from DVLA (age related number as using a USA frame) really great service they phoned me as well a I missed a bit on form three weeks after posting canโt complain with that ๐๐
Post by lc350pete on May 25, 2021 13:23:37 GMT 1
Just picked up my tank and bodywork from J&S racepaint near Bangor they did an amazing job will now be be able to finish her off just got to sort trim for the nose fairing and rear light amazing jo
