Pv clutch
Oct 22, 2020 13:54:09 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 13:54:09 GMT 1
No guys anyone help,advice after selecting 1 gear I am unable to change gear or get in to neutral
Pv clutch
Oct 22, 2020 15:12:17 GMT 1
via mobile
Post by midlifecrisisrd on Oct 22, 2020 15:12:17 GMT 1
If it changes in without engine running (rocking back and forth) but not when the engine is running it sounds like clutch drag
Pv clutch
Oct 22, 2020 15:55:49 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 15:55:49 GMT 1
It does change with engine not running any ideas on how to solve this?
Pv clutch
Oct 22, 2020 16:07:26 GMT 1
via mobile
Post by midlifecrisisrd on Oct 22, 2020 16:07:26 GMT 1
Adjust the cable to take out all the free play to see if that helps
Also try riding it
Pv clutch
Oct 22, 2020 16:19:50 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 16:19:50 GMT 1
Hi mate adjusting cable does not help unable to ride it on the road as it’s not legal
Pv clutch
Oct 22, 2020 16:22:24 GMT 1
via mobile
Post by midlifecrisisrd on Oct 22, 2020 16:22:24 GMT 1
Can you feel it dragging
Pv clutch
Oct 22, 2020 16:31:11 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 16:31:11 GMT 1
Yes mate
Pv clutch
Oct 22, 2020 16:38:31 GMT 1
via mobile
Post by midlifecrisisrd on Oct 22, 2020 16:38:31 GMT 1
What perch and cable are you using
Also does the marker on the arm line up
Pv clutch
Oct 22, 2020 16:43:14 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 16:43:14 GMT 1
Cable and perch are from norbo the adjuster lines up with the mark on the crank case when then the clutch is not pulled in.
Pv clutch
Oct 22, 2020 17:28:31 GMT 1
via mobile
Post by chrisg on Oct 22, 2020 17:28:31 GMT 1
If it changes in without engine running (rocking back and forth) but not when the engine is running it sounds like clutch drag Steve Are the rubber rings fitted between the plates. I always thought that they were there to separate the plates when the clutch is pulled in, but I have read that some people run without them and without issues.
Post by midlifecrisisrd on Oct 22, 2020 17:36:54 GMT 1
If it changes in without engine running (rocking back and forth) but not when the engine is running it sounds like clutch drag Steve Are the rubber rings fitted between the plates. I always thought that they were there to separate the plates when the clutch is pulled in, but I have read that some people run without them and without issues. They are there to stop the plates chattering If they go hard it usually causes clutch slip, not drag I never fit them Steve
Pv clutch
Oct 22, 2020 17:44:49 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 17:44:49 GMT 1
Last time I stripped the clutch there were no rubber rings i between the plates there was a little wear on basket tangs .
Pv clutch
Oct 22, 2020 17:47:46 GMT 1
via mobile
Post by Dixie Dean on Oct 22, 2020 17:47:46 GMT 1
How far past the casing mark is the clutch arm supposed to go when the clutch lever is pulled in?
Post by chrisg on Oct 22, 2020 20:33:03 GMT 1
Last time I stripped the clutch there were no rubber rings i between the plates there was a little wear on basket tangs . Depending on how bad the grooves are, this could be the cause of the clutch not letting go fully. Probably prudent to remove the basket the clean the grooves up. I use a needle file or sanding block if not that bad. Clean thoroughly with brake cleaner or similar afterwards.
Post by tacky1 on Oct 22, 2020 23:48:03 GMT 1
Sounds like the steels are warped, strip out the clutch plates and check the steels for warping...
Pv clutch
Oct 23, 2020 8:17:19 GMT 1
via mobile
Post by Dixie Dean on Oct 23, 2020 8:17:19 GMT 1
Steels ?
Post by muttsnuts on Oct 23, 2020 8:44:10 GMT 1
the ones between the fibres
Pv clutch
Oct 24, 2020 12:55:56 GMT 1
via mobile
Post by Dixie Dean on Oct 24, 2020 12:55:56 GMT 1
Hi guys just been into Webb’s Yamaha in Peterborough to check out my pv clutch steel plates out of tolerance, also springs out of tolerance so hopefully new parts will sort it out thanks guys
Post by 4l04ever on Oct 24, 2020 15:13:39 GMT 1
The fibre plates can also be causing the issue if they are not perfectly flat, so check those too. I put them altogether and make sure there are not gaps anywhere,
Pv clutch
Oct 24, 2020 15:44:54 GMT 1
via mobile
Post by Dixie Dean on Oct 24, 2020 15:44:54 GMT 1
Cheers we have checked them to
Pv clutch
Oct 24, 2020 17:03:16 GMT 1
via mobile
Post by flames on Oct 24, 2020 17:03:16 GMT 1
Hi guys just been into Webb’s Yamaha in Peterborough to check out my pv clutch steel plates out of tolerance, also springs out of tolerance so hopefully new parts will sort it out thanks guys Used to go there a lot when it was carnells. Spent many an hour dreaming of what I couldn't afford and then drowning my sorrows in a greasy burger in the snack bar outside.😁
