Post by zig on Oct 21, 2020 20:27:18 GMT 1
If i was to build a bike from the wheel's up with no registration / Log book or VIN etc how would you go about getting in recognized and registered as a UK bike??
Thanks everyone
ZiG
Post by shaunthe2nd on Oct 21, 2020 20:29:47 GMT 1
You need a VIN. No V5 is possible with a dating certificate, but bike needs a VIN as a starting point.
Post by midlifecrisisrd on Oct 21, 2020 20:36:22 GMT 1
Do you know if it's definately not been UK registered
Post by midlifecrisisrd on Oct 21, 2020 20:37:16 GMT 1
Just reread the no vin bit
Is it a custom frame
Post by chrisg on Oct 21, 2020 21:37:33 GMT 1
If i was to build a bike from the wheel's up with no registration / Log book or VIN etc how would you go about getting in recognized and registered as a UK bike?? Thanks everyone ZiG What frame is it? It must have a VIN or has it been erased? You can get an MOT on a frame VIN as well as insurance, all without a registration number.
Post by midlifecrisisrd on Oct 21, 2020 21:45:06 GMT 1
If it's a custom frame with no vin you need a donor frame/v5
Post by zig on Oct 22, 2020 20:44:26 GMT 1
basically if i have a frame i can identify as a rd250lc / rd350lc BUT because the vin has been removed because of years of powder coating how do i go about building a bike around it
to register for the road ??
i'm sure someone has came across this before ....maybe ?
ZiG
Post by shaunthe2nd on Oct 22, 2020 21:00:59 GMT 1
If it had a genuine VIN then it can usually be found on the RH side of the headstock. Remove the powder paint with dremel and gentle sand disc. If still not visible, then follow thos process... www.evidencemagazine.com/index.php?option=com_content&task=view&id=366If after all that, you don't find the original VIN, it is a ringer and has had serious efforts to disguise/remove the VIN. At this point, cut up the frame and sell the various brackets to offset your losses and buy a new legal frame. Will be much cheaper, less hassle and more legal that way.
Post by zig on Oct 22, 2020 22:03:38 GMT 1
If it had a genuine VIN then it can usually be found on the RH side of the headstock. Remove the powder paint with dremel and gentle sand disc. If still not visible, then follow thos process... www.evidencemagazine.com/index.php?option=com_content&task=view&id=366If after all that, you don't find the original VIN, it is a ringer and has had serious efforts to disguise/remove the VIN. At this point, cut up the frame and sell the various brackets to offset your losses and buy a new legal frame. Will be much cheaper, less hassle and more legal that way. Thanks for that.... i do know for certain it was from a genuine bike and has changed powder coating colours black twice blue once and white once....it has been stripped at the headstock and there is nothing left to recover from the VIN but yes i will look for a uk frame with log book , less hassle in the end ZiG
Post by midlifecrisisrd on Oct 23, 2020 9:10:11 GMT 1
I've seen a few that are barely visible after 1 rough blasting so can understand it going AWOL
