dezcbr
Post by dezcbr on Oct 18, 2020 21:22:56 GMT 1
Evening I noticed recently that my bike appeared to be knocking when cold. I have had a quick look and noticed that smoke was coming out of one side of the power valves between the barrels and the noise appeared to be coming from the valves. I got a long screwdriver and pushed on the power valve connector and the noise stopped. This is as far as I have got and would appreciate any advice or comments any YPVS experts may have. Is it likely that the power valve bushes require replacement?
justyr
Post by justyr on Oct 18, 2020 21:39:13 GMT 1
Checked the linkage bolts and the 2 moon shaped bush locators are tight?
Post by midlifecrisisrd on Oct 18, 2020 21:43:09 GMT 1
Bushes will be knackered and may have worn the barrel tunnel
Post by JonW on Oct 18, 2020 23:27:18 GMT 1
could be the seals and the half moons have worn, could be the barrels... only one way to know, whip em off.
dezcbr
Post by dezcbr on Oct 19, 2020 15:44:47 GMT 1
Thanks appreciate the advice, looks like I better get the socket set out. If the barrels are worn can they be repaired?
