Post by billyboy on Oct 17, 2020 8:45:23 GMT 1
Anyone had a play with this and got any results ? Cheers
lc2
Post by lc2 on Oct 17, 2020 13:36:21 GMT 1
Try inputing your data and see what dimensions it suggests and compare it to known expansion chambers,I have tried a few over the years and they can suggest dimensions which clearly wont work. The two types of software I used where both paid for and all the data used was correct and taken from my own engine entering realistic RPM and predicted BHP.
Post by billyboy on Oct 17, 2020 15:08:37 GMT 1
Try inputing your data and see what dimensions it suggests and compare it to known expansion chambers,I have tried a few over the years and they can suggest dimensions which clearly wont work. That's what I did mate and it gave me a belly diameter of over 300 mm. Thought it was me putting in bad data .Not sure where I went wrong tho .
Post by pedheadfred on Oct 17, 2020 17:24:49 GMT 1
300mm belly 🕵️ sure that's not outside diameter of flat cone before rolled? If not it's rather a large size belly indeed
Post by billyboy on Oct 17, 2020 18:21:29 GMT 1
300mm belly 🕵️ sure that's not outside diameter of flat cone before rolled? If not it's rather a large size belly indeed It's this covid , I've pilled it on 😅 No it was the diameter .
Post by bare on Oct 17, 2020 19:57:28 GMT 1
You expected Worthwhile results from a Freebie?? Phone app. Really?
Post by billyboy on Oct 18, 2020 0:42:35 GMT 1
No , got it on me tablet 😉
Post by billyboy on Oct 18, 2020 9:33:12 GMT 1
You expected Worthwhile results from a Freebie?? Phone app. Really? Nothing changes much with you Bare , been away for a while and you're still a cantankerous fella . Have you ever heard of torque Obd scanner diagnostics that is a phone app , it's had 10 million downloads and works very , very well , there are better ones out there now, all for free , all on a phone ! .
lc2
Post by lc2 on Oct 18, 2020 9:56:24 GMT 1
I have the free Torque Light app with the ELM dongle and it works spot on I also have a all systems all vehicles OBD ready that cost a fortune but the Torque light app still takes some beating for engine codes.
Post by billyboy on Oct 18, 2020 12:04:30 GMT 1
I have the free Torque Light app with the ELM dongle and it works spot on I also have a all systems all vehicles OBD ready that cost a fortune but the Torque light app still takes some beating for engine codes. 👍 And all of that on a phone ,who'd of thunk it !
