Post by russpuss on Oct 5, 2020 22:24:31 GMT 1
MOT showed 75k front and 75k rear. Bike was 3” off floor when weighed either end. Does this make it 150k wet as the tank was full?
Post by Tobyjugs on Oct 5, 2020 22:54:58 GMT 1
The fuel in the tank is a large weight increase to a bike. I reckon the 3 inch lift either way will make a little bit of extra weight but not much.
Post by JonW on Oct 6, 2020 0:19:22 GMT 1
They weighed the bike during the MOT? What was the reason for that Russ or is that normal now?
Post by russpuss on Oct 7, 2020 18:46:08 GMT 1
They weighed the bike during the MOT? What was the reason for that Russ or is that normal now? For the brake efficiency I believe
2taol
Post by 2taol on Oct 7, 2020 18:58:03 GMT 1
im not sure its an accurate way of total weight measurement.
lifting the front, what exactly is being weighed? front wheel, forks, clocks handlebars obviously, but how much of the frame? how much of the tank? how much of the engine and pipes?
it works for them and how the computer is formulated i guess
Post by JonW on Oct 8, 2020 0:04:54 GMT 1
Wow, interesting.
Post by midlifecrisisrd on Oct 8, 2020 8:53:09 GMT 1
The bike only has 2 points of contact with the ground so the total weight will be distributed between these 2 points
If you can't forward or back to get on a scale which is not flush with the ground it will change slightly as the weight distribution will change a small amount but probably negligible for these purposes
Post by midlifecrisisrd on Oct 8, 2020 8:54:56 GMT 1
MOT showed 75k front and 75k rear. Bike was 3” off floor when weighed either end. Does this make it 150k wet as the tank was full? Should be a baw hair less as lifting either end will put slightly more weight on the other as per my other comment Steve
Dave B
Post by Dave B on Oct 8, 2020 9:45:02 GMT 1
"baw hair less ". No much less than that, a couple of gnat's maybe or 0.46 smidgeons in the new measurements.
