Post by Dixie Dean on Oct 4, 2020 13:13:10 GMT 1
Hi guys can anybody tell me the best way to clean the petrol tap and change the diaphragm on a pv petrol tap?
Post by speedar on Oct 4, 2020 13:37:01 GMT 1
Search on You Tube. “How to rebuild any motorcycle petc.ck fuel switch” seams comprehensive video from couple of years ago.
Post by roblc350 on Oct 4, 2020 13:42:37 GMT 1
i waisted my money trying to refurb one with a service kit ended up buying a new one from Norbo
Post by speedar on Oct 4, 2020 14:05:46 GMT 1
Yes. Did the same. Couldn’t get fuel to stop flowing to carbs. Tried a couple of kits no luck. New fuel tap. Problem solved!
Post by Dixie Dean on Oct 4, 2020 16:04:52 GMT 1
Ok thanks
Post by midlifecrisisrd on Oct 4, 2020 16:11:00 GMT 1
I've refurbed a few with no problems
As long as there is no corrosion on the tap parts it should be fine but you need to clean everything and a good idea to give the diaphram spring a little stretch to perk it up
Post by Dixie Dean on Oct 4, 2020 16:41:15 GMT 1
What did you use to clean everything ?
Post by midlifecrisisrd on Oct 4, 2020 16:45:52 GMT 1
Carb cleaner and a little fine scotchbrite pad for stubborn crud if required
Post by Dixie Dean on Oct 4, 2020 17:19:42 GMT 1
Ok thanks
Post by Dixie Dean on Oct 21, 2020 11:37:50 GMT 1
Hi mate when changing the diaphragm the new kit does not have a hard plastic piece in the middle is that correct or are you supposed to swap it over,any help
Post by JonW on Oct 21, 2020 12:37:59 GMT 1
Swap it over Dean.
Post by midlifecrisisrd on Oct 21, 2020 12:42:45 GMT 1
Yep swap it
From memory you need a layer of the diaphram each side of it so you need to pop one layer through the hole
Post by JonW on Oct 21, 2020 13:04:37 GMT 1
Thread it through very very gently, dont rip it.
Post by Dixie Dean on Oct 21, 2020 16:31:56 GMT 1
Got there in the end thanks
Post by stusco on Oct 21, 2020 17:17:48 GMT 1
i waisted my money trying to refurb one with a service kit ended up buying a new one from Norbo Me too filled my crankcases first though
