Gord
Post by Gord on Sept 14, 2020 20:05:37 GMT 1
Looking for help....How tightly should the inner shaft (#3 in this pic) fit into the swing arm bushings? Mine is tight like a tiger, and when it’s assembled there is a lot of friction.
Post by flames on Sept 14, 2020 20:24:31 GMT 1
You want it tight so there is no play but not so tight you struggle to get it in or out.. When it is all tightened up swingarm should hinge freely.
Gord
Post by Gord on Sept 14, 2020 20:26:45 GMT 1
You want it tight so there is no play but not so tight you struggle to get it in or out.. When it is all tightened up swingarm should hinge freely. Mines a struggle to get in and out so that’s probably the issue with it. Thanks for this! I think the outer bushings need attention.
Post by flames on Sept 14, 2020 20:32:47 GMT 1
Mine is hard to move initially but once it starts to move it slides out smoothly with a bit of resistance but can push out with my finger. Have you fitted new bushes or pulled it apart?
Post by JonW on Sept 15, 2020 1:24:11 GMT 1
Sometimes when you fit new bushes they mushroom and catch the collar (no.3). Pull it apart and you should see any witness marks where its worn on the bushes. you may need to reem them out.
If you run it tight thinking 'it will wear in', it might, but it will create a lot of heat and could seize solid.
Post by steeley on Sept 15, 2020 12:20:02 GMT 1
Had this years ago on my lc ,a friend of mine had a batch of swing arm bushes made for me at his place of work . In the end i carefully worked on both ends of the sleeve to get a good fit in the bushes .
Gord
Post by Gord on Sept 24, 2020 18:09:19 GMT 1
Mine is hard to move initially but once it starts to move it slides out smoothly with a bit of resistance but can push out with my finger. Have you fitted new bushes or pulled it apart? I had only pulled it apart and ended up buying new bushes - works great now.
Post by flames on Sept 24, 2020 19:40:50 GMT 1
Mine is hard to move initially but once it starts to move it slides out smoothly with a bit of resistance but can push out with my finger. Have you fitted new bushes or pulled it apart? I had only pulled it apart and ended up buying new bushes - works great now. That's great bud. If only everything was so easy to fix.😊
Post by Norseman on Oct 24, 2020 9:43:35 GMT 1
You may need to use shim washers on the end of sleeve 3 in the exploded diagram, if this sleeve is slightly shorter than the overall width of swingarm and assembled bushes, when you tighten the swingarm pivot bolt the whole assembly will bind and cause friction or no movement at all.
Shim the end of sleeve 3. so that when pivot bolt is tightened to correct torque the swingarm moves freely without side to side play (End Float).
