tucad
Post by tucad on Sept 10, 2020 15:49:22 GMT 1
Hi just got a rd250 need to know if it's a e or a f model it is 1a2 432 can anyone help.
ajh
Post by ajh on Sept 10, 2020 18:26:20 GMT 1
1A2 is a 250d frame. The giveaway is the footrests, they 'hoop' under the frame on a D, E/F are bolted to the side of the frame
Post by reedpete on Sept 10, 2020 19:54:07 GMT 1
No....all D to F RD250 start 1A2
But 1A2-4 is an F
tucad
Post by tucad on Sept 10, 2020 20:02:13 GMT 1
No....all D to F RD250 start 1A2 But 1A2-4 is an F
tucad
Post by tucad on Sept 10, 2020 20:04:17 GMT 1
I've got a 400d the footrest go under the 250 are bolted to the side I just needed to know if it's a e/or.f model.
tucad
Post by tucad on Sept 10, 2020 20:09:15 GMT 1
I've been told that the 250e starts from 1A 430101/ to 450000.is this right.
Post by reedpete on Sept 10, 2020 20:27:36 GMT 1
Think You mean 1A2-4 not 1A 4
Post by reedpete on Sept 10, 2020 20:35:43 GMT 1
tucad
Post by tucad on Sept 10, 2020 20:47:34 GMT 1
Yes that's what I meant 1a2 looking at that list you put up mine is a 1979 model 2r8 but still doesn't say e or f it's under the one that says e.
ajh
Post by ajh on Sept 10, 2020 20:48:52 GMT 1
soz, my mistake I was thinking of the model number 1a2 for 250d, 2r8 for e/f. Your frame number is a 79 bike according to yamaha model code list but doesnt say if its e or f.
Post by tony2stroke on Sept 10, 2020 20:59:34 GMT 1
As Peter said, its an F 1979 2R8 as denoted by the frame number, 1978 was an E, 1980 was the start of the LC range.
Post by reedpete on Sept 10, 2020 20:59:57 GMT 1
Guys...1A2-22 is a 2R8 and 1978 ...first year of 2R8 ...so it’s an E
1A2-4 is 2R8 for 1979 so it’s a F !
So as I said an hour ago your is an F ... What’s the confusion?
Post by tony2stroke on Sept 10, 2020 21:11:20 GMT 1
I don't see how there is any confusion either, its the numbers after that count, 1A2 430101 to 450000, 1A2 432 means F, can't be any easier than that.
tucad
Post by tucad on Sept 10, 2020 21:13:02 GMT 1
Thanks so I've got a f model is it true 1a2 means 250 43 is f model and the rest of the numbers are when it come off the production line is this true or false.
Post by tony2stroke on Sept 10, 2020 21:19:28 GMT 1
1A2 430101 is the start of the 250 F production, the numbers after that are sequential to the bikes being produced up to final for that model of 1A2 450000
After that the LC was produced.
Post by reedpete on Sept 10, 2020 21:26:04 GMT 1
You almost got it ! If it’s a 2R8 Ie a UK/EU bike then anything starting 1A2-4 Is an F....the numbers after that are just the index numbers out the factory.
In pure index numbers the 1A2-40 up to 4299 are other country models So not 2R8 and you can disregard.
Essentially in the Uk we have four years of coffin tank Aircooled 250 C to F
1976 ...they all start 1A2-00 Those are the Cs, 1977 Ds all start 1A2-20, 1978 Es all start 1A2-22 and the F.......1979. all start 1A2-43
