ahthud
Post by ahthud on Aug 28, 2020 20:41:47 GMT 1
Hi, does anyone know where I could get 2 bushes made up from mild steel at 18mm od x 16mm id x 95mm long?
Thanks in advance.
Post by rich on Aug 28, 2020 20:49:46 GMT 1
That's basically a sleeve. I'd have a look on ebay for some mild steel tube, 18mm od with 1mm wall thickness and cut to length yourself
Post by JonW on Aug 29, 2020 1:49:38 GMT 1
Exactly what rich said. Easy and cheap to do yourself with a pipe cutter (to mark it) and a hacksaw.
Post by andy748 on Aug 29, 2020 9:32:56 GMT 1
Post by earthman on Aug 29, 2020 11:35:21 GMT 1
Good find, I have a small lathe and would have offered to make it but I don't have a 16mm drill bit, sure I have a boring bar so could get there in the end. It's just not worth the time and hassle when you can buy a tube in the correct dimensions.
