Post by simon998 on Aug 24, 2020 14:57:49 GMT 1
Looking to do a full rebuild on the 10w engine, anywhere you can get a list of the bearing sizes so I don’t have to pay the premium to have the m delivered in Yamaha bags?
Post by mellow on Aug 24, 2020 22:29:21 GMT 1
got my bearings from simply bearings. The numbers will be on your old bearings
Post by Gunny on Sept 1, 2020 16:31:29 GMT 1
I just went to local bearing supplier with the old bearings which had the numbers on them. Roughly a fiver each
Post by museumman on Sept 2, 2020 12:01:10 GMT 1
CMSNL kindly show all the seal sizes on their site and many bearing types. I stayed up all night on there once and then on to a bearing supplier to see if I could get the best quality cheaper. I managed to get a KOYO and NTN crank couple made in Japan. C3 and C4 As Gunny says it's easier and saves time just to visit a local bearing supplier. I've done that when in England the guy at my local knew most of them in his head and took him minutes to get them on the counter.
My online order did contain a ballsup on my fault too
Post by graeme6 on Sept 7, 2020 21:03:59 GMT 1
Here is a list I drew up during my rebuild. Hasn't copied over very well but columns are Part name - Yamaha part no, - Drawing position no. - size - generic part no. Clutch flanged half nut 9017912244 11 M12x1x8.8mm Clutch basket half nut 90170-12337 . seal output shaft 93102-20143-00 24 20X38X5 seal kickstart 93102-20309-00 12 20x30x5 tc seal gearshift shaft 93101-12060-00 1 12x21x4 tc seal LH crankshaft 93306-30421-00 15 25X40X8 tc seal RH crankcase 93103-28097-00 16 28X40X8 tc seal clutch arm 93104-14004-00 26 14X25X5 tc Shaft seal 25x12x10 Water hose connector O ring 93210-16275 3 16mm IDx2.5mm Oil pump shaft shim 90201-08624 14 crankshaft bearing RH 93306-30301-00 23 6304 C3 17x47x14 crankshaft bearing LH 93306-20529-00 13 6205 C4 25x52x15 Balance shaft bearing left 93306-30201 22 6302 Balance shaft bearing right 93306-30305 23 6303 Needle bearing right 93317-31529 22 genuine only Needle bearing left 93311-41530 9 genuine only Primary gear shaft r/h bearing 93306-30303 8 6303Z Balance shaft nut 90170 12337 seal front forks 93110-33018-00 8 & 28 45 x 33 x 11 fork seal dust covers 1GU - 23144 - 00 10 & 30 45x33
Post by seang14 on Oct 12, 2020 18:35:22 GMT 1
Are the Bearings for a DT200LC Different from a125
Cheers Sean G
