ahthud
Post by ahthud on Aug 22, 2020 20:39:37 GMT 1
HI has anyone fitted a front end from an RS125 on an F2 YPVS?
stasky
Post by stasky on Aug 22, 2020 21:34:30 GMT 1
nope,but did fit a set to an old xs400,so shouldnt be too difficult,anythings possible,trouble is finding a decent set,there cheap enough for a reason, all these forks are either severely neglected or poorly made,i dont have the answer,but i do know its hard to find a good set , i used the ones 2006 onwards with the radial front caliper,and 1 thing to point out,these are single disc 014 by michael macmillan, on Flickr
Dave B
Post by Dave B on Aug 23, 2020 10:28:31 GMT 1
They are a little odd in that in true Aprilia fashion, they have the spring in one leg and the damper in the other. I'd guess they would be a bit soft on an F2. On the other hand if you want a pair of them to try for a fitting, I have a pair that need rechroming that you can have for £15 plus postage. Message me if you would like them. Cheers Dave
stasky
Post by stasky on Aug 23, 2020 12:29:37 GMT 1
They are a little odd in that in true Aprilia fashion, they have the spring in one leg and the damper in the other. I'd guess they would be a bit soft on an F2. On the other hand if you want a pair of them to try for a fitting, I have a pair that need rechroming that you can have for £15 plus postage. Message me if you would like them. Cheers Dave that was on the rs250,s ,not the 125,s,the rs125 has springs both sides,and there definately not soft,they worked really well on my xs400,with that big heavy engine,its a popular mod with the xs crowd
Dave B
Post by Dave B on Aug 24, 2020 10:23:39 GMT 1
I guess you must have the post 2006 forks. The ones that I took off my 2001 model RS125 definitely have a very soft spring and the damper on the right (brake caliper) side, and just a strong spring on the left one. This is not just theory or memory, I've just been in the garage and tried them! The comment about the springs being soft came from a friend based on his experiences racing one, also a pre 2006 model.
stasky
Post by stasky on Aug 24, 2020 21:45:09 GMT 1
yep,mines were 2006 onwards,with the radial brake caliper,so must just be 2006 onward with 2 springs
