Post by lcmarky on Aug 19, 2020 13:34:24 GMT 1
Does the original radiator cap have the two flanges or were they just round?
Looking for a NOS one or similar.
Thx
Post by veg on Aug 19, 2020 13:55:48 GMT 1
Original had the two ‘flanges’ then they changed to round ones if you ordered a new one. So if you’re after 100% original you’ll need the early type.
Post by lcmarky on Aug 19, 2020 14:20:56 GMT 1
Original had the two ‘flanges’ then they changed to round ones if you ordered a new one. So if you’re after 100% original you’ll need the early type. Thank you & that explains why I see the non flanged ones available now... I'm using one of an old rad' but really need a perfect bike for LC#1..
Post by Tobyjugs on Aug 19, 2020 15:50:22 GMT 1
I used one from an old V8 rover radiator it was exactly the same as my old LC cap. I didn't check to see if it had the same opening pressure.
Post by midlifecrisisrd on Aug 19, 2020 16:25:12 GMT 1
I used one from an old V8 rover radiator it was exactly the same as my old LC cap. I didn't check to see if it had the same opening pressure. Just had a quick look around and all I've seen are 15 psi so near enough 1 bar The stainless ones are nice 😎 Steve
Post by veg on Aug 19, 2020 16:26:41 GMT 1
Mines from a mitsubishi and its more Tz in style if the OP wants an original not so sure if you can get similar, no doubt someone will know.
Post by lcmarky on Aug 20, 2020 11:38:18 GMT 1
I'm gonna double up the gasket as a first step as mine looks just right aesthetically.
