Found this on an old thread from Xavier
2014:
ENGINE
cylinder head satin
cylinders satin
clutch cover satin
Ignition cover satin
radiator satin
Water joints satin
engine stay rod gloss
engine mounting brackets gloss
engine stay rod bracket olive green
kick lever olive green
water hose clamp olive green
carburetor and airbox clamp olive green
radiator cap olive green
clutch and ignition cover screws olive green
cylinder head bolts, studs & washers olive green
engine screws, washers and nuts zinc silver
CHASSIS
frame gloss
Swingarm gloss
rear frame stay gloss
Lifting handle bar gloss
side and central stand gloss
wheels satin
FRONT
handle bar satin
handle switch (left and right) satin
Brake Lever satin
Clutch lever and braket satin
horns and outer brackets satin
top yokes satin
Main switch housing satin
Speedo drive housing satin
bottom yoke olive green
top fork ball cover (head race cover) zinc silver
twin horns bracket olive green
headlight bracket gloss
front indicator stems olive green
indicator fixing bolts, nuts and washers olive green
clocks bracket olive green
mirror stems olive green
front mudguard bracket zinc silver
headlight rim Chromated
MIDDLE
stand springs zinc silver
front & rear footrest bracket olive green
front & rear footrest stems olive green
pipe exhaust Black coating
gear pedal + rod and lever Chromated
Seat Latch and Lock satin
unlock seat bracket olive green
levers on seat latches zinc silver
REAR
rear sprocket hub satin
rear sprocket gloss
chain puller zinc silver
rear handle bar Chromated
rear reflector bracket olive green
BRAKING
master cylinder and splitter joint satin
brake caliper satin
disk brake satin
rear brake pedal olive green
drum brake shoe plate satin
drum reaction bar gloss
rear brake lever (on plate shoe) Chromated
rear brake rod zinc silver
MISC
wheels, engine and rear arm axles zinc silver
others screws, washers and nuts zinc silver
