Post by flames on Aug 15, 2020 12:45:04 GMT 1
I don't suppose anyone happens to know how much a 31k rear wheel with disc and sprocket fitted weighs in kg's?
Also the weight of rear caliper?
Might have a change of plan on my build....
Post by 4l04ever on Aug 15, 2020 20:27:39 GMT 1
Post by flames on Aug 15, 2020 20:58:23 GMT 1
Jesus!!!! You would have thought with 10 seconds notice, he would have moved out of the way 😁
Post by tacky1 on Aug 15, 2020 21:01:46 GMT 1
Bored here, To friggin hot to do anything YPVS back wheel, disc, cush, sprocket and hub. 7.645 KG YPVS front wheel with discs 8.78 KG RGV front wheel with discs. 7.91 KG YPVS bare frame 14.91 KG. Did I mention I was bored
Post by flames on Aug 15, 2020 21:04:28 GMT 1
Nice one thank you. There's fzr 600 3he fr and rear ends in the garage if you run outta things to weigh.😁
Post by tacky1 on Aug 15, 2020 21:05:35 GMT 1
Nice one thank you. There's fzr 600 3he fr and rear ends in the garage if you run outta things to weigh.😁 😂😂🖕🖕
Post by flames on Aug 15, 2020 21:14:26 GMT 1
Is that with or without tyres? That's nearly 5kg lighter than LC!!! And 3kg lighter than the xj front. Rear is 10 kg lighter! Rgv nearly half the weight.....
Post by veg on Aug 15, 2020 21:20:22 GMT 1
Or you could buy a proper set of magnesium wheels at 2kg 😁
Post by flames on Aug 15, 2020 21:22:33 GMT 1
Wouldn't want to be accused of nicking your idea's veg. 😁
Post by flames on Aug 15, 2020 21:23:59 GMT 1
Must make a helluva difference tho? I would need to grow my Belly 1st to weigh the bike back down.😁
Post by tacky1 on Aug 15, 2020 22:54:32 GMT 1
No tyres. Bearings fitted.
Post by flames on Aug 15, 2020 23:21:12 GMT 1
🤣🤣🤣🤣 no wonder they were so light. I have pretty much decided I am going to go PV rear wheel tho. Cheeds
Post by JonW on Aug 16, 2020 8:31:27 GMT 1
Late PV wheels are lighter, their disks too...
Post by flames on Aug 16, 2020 14:59:00 GMT 1
Late PV wheels are lighter, their disks too... Cheers Jon. I had heard this but although a bit of reduction in weight is welcomed it's not the main purpose. I have an XJ600 front wheel which i am fitting in FZ600 forks and the wheel is same style as early pv wheels, just wanted to make sure the pv wheel doesnt add too much weight before i decided whether or not to stick with lc wheels.
