Post by martinrs2k on Aug 12, 2020 16:21:15 GMT 1
I'm not very technically minded, but a mechanic who I respect has told me he thinks my LC gearbox is noisy especially in 6th gear.
How easy is it to get the parts to rebuild the gearbox (if a rebuild is needed) or to replace worn gears etc.
And where is the best place to get the parts from?
Post by speedar on Aug 12, 2020 16:37:01 GMT 1
If you are splitting cases to examine gearbox you would then be looking at probably recon crankshaft and rebore etc no doubt depending on condition. I recently rebuilt a TDR 250 motor and one of the gears showed signs of wear. No longer available new however was able to obtain a nos part on Ebay from Greece! Check Fowlers website to see what parts of gearbox still available new. You either run the bike with fault with the chance of a gearbox failure (gulp-dangerous/expensive!) or strip engine to rectify sooner than later. Best of luck.
lc2
Post by lc2 on Aug 12, 2020 17:33:06 GMT 1
If you suspect a gearbox fault don't use the bike , if it locks up you are in trouble as pulling in the clutch won't make any difference . These engines are not difficult to work on and little needed re specialist tools, I recently rebuilt my Yamagamma donor engine and one pair of gears was close to breaking up.I have a good gear cluster set if needed.
Post by jon on Aug 12, 2020 17:59:20 GMT 1
Good old LC 6th gear worn out.
They were too thin, thatβs why they widened the PV.
Post by midlifecrisisrd on Aug 12, 2020 18:04:47 GMT 1
Even my pv back in the day whined in 6th π
Post by flames on Aug 12, 2020 18:50:50 GMT 1
Mine gets to 6th then eats the top of the pistons. π
Post by 4l04ever on Aug 12, 2020 23:22:23 GMT 1
Mine gets to 6th then eats the top of the pistons. π Does your name come out your exhausts when that happens? ;-)
Post by flames on Aug 12, 2020 23:56:53 GMT 1
π€£π€£π€£ probably.....but it's hard to tell through the years in my eyes.π
Post by midlifecrisisrd on Aug 13, 2020 8:50:49 GMT 1
π€£π€£π€£ probably.....but it's hard to tell through the years in my eyes.π And crap in your pants π Steve
Post by flames on Aug 13, 2020 9:01:23 GMT 1
π€£π€£π€£ probably.....but it's hard to tell through the years in my eyes.π And crap in your pants π Steve The first time was a bit hairy. I was going past a line of cars, got to about 90-95 and as I got to the last car she locked up. Luckily the road was damp so didn't snatch when I got the clutch dipped. So I kind of skidded / freewheeled past the last car then watched as all the cars cruised past the 'feckin idiot on a bike'.π
Post by martinrs2k on Aug 14, 2020 11:23:40 GMT 1
If you suspect a gearbox fault don't use the bike , if it locks up you are in trouble as pulling in the clutch won't make any difference . These engines are not difficult to work on and little needed re specialist tools, I recently rebuilt my Yamagamma donor engine and one pair of gears was close to breaking up.I have a good gear cluster set if needed. Thanks for the offer, is this all I will need for the rebuild or will I need other items (apart from gaskets and seals)?
Post by 4l04ever on Aug 14, 2020 17:59:36 GMT 1
New bearings might be worth putting in. The output bearing behind the sprocket is a standard bearing (6305NR), so I just get a decent branded one and remove the ring.
