Post by tipfinchy on Aug 11, 2020 13:13:20 GMT 1
Came off my hybrid with vj22 front end , I'm guessing its rgv but seeing i know best part of nothing I thought I would ask , thanks Mart
Post by midlifecrisisrd on Aug 11, 2020 13:21:12 GMT 1
Looks rgv to me 😉
Post by tipfinchy on Aug 11, 2020 13:29:32 GMT 1
thanks Steve , sometimes its ok to know nothing other times its a pain mart
Post by veg on Aug 11, 2020 15:14:36 GMT 1
Or gsxr 400? I fitted gsxr one to my old hybrid virtually the same as rgv from memory but cheaper
Post by stusco on Aug 11, 2020 16:30:13 GMT 1
Looks like the rgv one i took off my rg
stasky
Post by stasky on Aug 11, 2020 19:27:23 GMT 1
it looks like an rgv master cylinder, but its not, rgv ones are 5/8 ,just been out to shed to double check, and thats clearly a 14mm master cylinder,i can see the 14 on it quite clearly
Post by tipfinchy on Aug 11, 2020 20:19:08 GMT 1
it looks like an rgv master cylinder, but its not, rgv ones are 5/8 ,just been out to shed to double check, and thats clearly a 14mm master cylinder,i can see the 14 on it quite clearly think you might be right , on the underside of the lever it has 5eb which i think is early R6 yam? or could that just be the lever? , every day is a school day mart
stasky
Post by stasky on Aug 11, 2020 20:46:46 GMT 1
lever could be r6 lever then,dunno if any of them ran a 14mm master cylinder tho,ones ive had were 5/8,most twin disc front brakes would use a 5/8,tdr250,early rd250/400 also ran a 14mm master cylinder but they were the ones with built in reservoirs,most single disc yams used a 1/2 front master cylinder,xt350,dt200 ran an 11mm master cylinder,dont really know why yamaha used a 14mm master cylinder on the tdr250 as its a single disc also,must be something to do with the disc size,can all get quite confusing,that system u have there may well work ok, but personally i would use a 5/8 master with those calipers
Post by Tobyjugs on Aug 12, 2020 14:47:30 GMT 1
That master cylinder and reservoir screams 5EB R6, I have a complete front end bolted to my RD and the brakes are nuts combined with Goldfren pads. I regularly think about going down to one disc.
I cant wait to hear some feed back from your new Brembo unit.
