Post by rattler on Aug 10, 2020 22:16:23 GMT 1
Hi - I'm looking for guidance around speedo drive options when fitting a VJ22 front end. These might be naive questions, but this is new to me, and I've not fully investigated this Seems the standard 4L0 speedo drive is too small to fit the VJ22 axle, So what are my options here? Electronic speedo - ? - If so, assume I will need a drive sized spacer to replace it? Or can the standard speedo drive be adapted to fit? Or are there alternative speedo drives that will fit? Thanks in advance Tim
Post by chrisg on Aug 10, 2020 22:23:43 GMT 1
Post by mouse on Aug 11, 2020 7:54:42 GMT 1
If you are using VJ22 forks as well use a VJ22 speedo drive, also an RGV cable will attach to LC clocks, no prob
Mouse
Post by midlifecrisisrd on Aug 11, 2020 8:01:52 GMT 1
As above rgv drive (think rf600 is same) and either rgv or Bandit cable
Post by rattler on Aug 11, 2020 9:01:36 GMT 1
Thanks guys - it would be great to be able to see what other models use the same drive as the RGV prices seem to attract a premium on Ebay (really Sherlock?)
Post by midlifecrisisrd on Aug 11, 2020 9:16:08 GMT 1
If you are up for some modifications I used an xjr400 and an rd400 one on my last 2 hybrids as were 17mm spindle
Not sure how the drive tab, washer and seal set up would work but worth a try
Also look at bandit drives as although they are a different cable end type at the drive they may be easier to get to fit
Just used a gs500 one on my kettle/TR build but that's 15mm spindle
Post by JonW on Aug 11, 2020 9:18:37 GMT 1
I used the RGV on mine, the RGV OEM cable fits the LC speedo.
I then went GPS later. all info on my site.
Post by flames on Aug 11, 2020 10:46:10 GMT 1
Been thinking about a GPS Speedo go mine, are they reliable? As in do they lose signal much / at all?
Post by JonW on Aug 11, 2020 13:28:20 GMT 1
has to have line of sight to the satellites...
