Post by arrdy350 on Aug 7, 2020 17:33:23 GMT 1
Hello
I am doing up an F1 and looking for some advice on whether or not to take my waterpump out . I took the engine apart over 2 years ago in a bit of a rush and just now about to put it back together. The bike has not ran for a long time.
Thanks arrdy
Post by stusco on Aug 7, 2020 17:37:04 GMT 1
You may want to check the pump shaft and change the seal,mine was only a couple of years old and the seal had failed mixing the coolant with the oil
Post by arrdy350 on Aug 7, 2020 17:52:49 GMT 1
Thanks 👍
Waterpump
Aug 7, 2020 20:19:36 GMT 1
via mobile
Post by flames on Aug 7, 2020 20:19:36 GMT 1
I agree with above. Do as much as you can while the motor is apart. Getting it built up and back in the bike only to find a seal gone and needs stripping again is a real pitta.......not to mention expensive.
Post by arrdy350 on Aug 7, 2020 20:28:46 GMT 1
Cheers, I will take the waterpump out then
