Post by jon on Aug 3, 2020 18:57:46 GMT 1
Hi all,
I’ve a question on long stoke cranks. Specifically the +4mm.
If these are used with YPVS barrels or say an Athena 392cc do the ports need lowering to the floor of the new BDC?
Is it essential or recommended. If it’s done is it too much port timing?
Post by midlifecrisisrd on Aug 3, 2020 19:43:33 GMT 1
I'd say it is highly preferred
If you look at how narrow the transfer ports are dropping them 2mm makes quite a difference to the port area
My next bit of info may of got confused a bit but I'm sure slinger said the 1ua barrels have slightly too much port duration and the +4 crank corrects this
Post by muttsnuts on Aug 4, 2020 15:48:04 GMT 1
you need different pistons for a start, once you have those then you can measure your port timing and adjust to suit your requirements, flooring of the ports is generally required, you also need to factor in your base gasket thickness, ideally do a dry build with the gaskets you are going to use so that your measurements are correct
