Post by shaunthe2nd on Jan 25, 2021 16:29:09 GMT 1
Alan, Its to fix the unit to the mechanism spindle. Without it the needle doesn't hold and works loose. You can get 'similar' needles without the brass centre and they are rubbish!
The spindle is 1.0mm diameter. Shaun.
Post by shaunthe2nd on Jan 25, 2021 16:37:13 GMT 1
Alan, it may just be the perspective on your drawing, but the orange needle is tapered. 2.6mm at the fat end near centre, 1.5mm at the thin end. Orange bit is 36mm long. Black bit is 12mm diameter. Dainty little thing.
Post by midlifecrisisrd on Jan 25, 2021 18:51:14 GMT 1
Usually a new needle is made as a replacement so you will always have the brass insert
Just needs a hole for it, easy enough to bond it in If not an interference fit
Post by alankelly on Jan 25, 2021 19:55:23 GMT 1
Ok Found a (broken but glued) needle I see the orange part is hot staked onto the black part Do you think itโs worth seeing if we can just print the needle like in the picture of the model so to replace you just remove the orange needle and replace keeping the black centre part I will try to remove the needle later tonight
Post by midlifecrisisrd on Jan 25, 2021 20:00:30 GMT 1
It would certainly be better than no needles at all ๐
Post by alankelly on Jan 25, 2021 20:07:09 GMT 1
Ok that works As Logan is working from home he wants to draw it up using his fusion 360 software and try first to print one in PLA to see what it looks like
Post by steve63 on Jan 26, 2021 8:08:39 GMT 1
I have a rev counter with no case, just the body.ย I found it the other day in a box of bits and gave it a clean up. I did consider getting one of your cases for it but I have no glass either although who know what I might dig up laterย Despite being in a box for 25+ years the needle is in tact. If the needles are the same you can borrow it. Steve, Be careful with that, only take the needle off if you absolutely need too. I have done dozens, and my hit rate is about 50% success. They either snap in half, or break away at the pivot shaft. Replacement needles are not available. Only option isย to buy another clock just for the needle, and don't cry if that one snaps when you remove it. I've cried a lot! I have done work on lots of other similar clocks of the era, and the original 4L0/4L1 needles are by far the worst to remove. Shaun. I wasn't thinking of trying to take the needle off myself. It doesn't seem like a good idea by the sound of it. The pin that works as a needle stop was bent. I put a piece of fine brass tube over if and straightened it. I thought there was a good chance of it breaking but it worked out fine. Just cleaned it up with break cleaner and compressed air and stuck it in a bag.
Post by Tobyjugs on Jan 26, 2021 9:53:47 GMT 1
Happy Birthday Alan
Post by alankelly on Jan 26, 2021 9:56:09 GMT 1
Post by shaunthe2nd on Jan 26, 2021 15:55:40 GMT 1
Happy birthday Alan. This is what usually happens to these little buggas... I have checked my stash and have a few spare so will put up a for sale thread for anyone in dire need of one.
Post by alankelly on Jan 26, 2021 17:59:20 GMT 1
Hi All Is the correct colour for the speedo tacho needles? Going to look to make in a PETG as is pretty durable like your indestructible coke bottle that is the same material Best wishes Al
Post by alankelly on Jan 26, 2021 18:09:47 GMT 1
Loganโs first attempt in a white pla Needs a tweak but looks promising
Post by Yogi on Jan 26, 2021 18:12:27 GMT 1
Hi Alan
Hope your well mate
Have you got any of the ypvs horn covers for sale yet
Cheers Matt
Post by alankelly on Jan 26, 2021 18:36:56 GMT 1
Not yet
Sorry Its my fault I have got snowed under with a Koso clock housing project for somebody but Loganโs going to pick this project up hopefully tomorrow with a bit of help from me
That the trouble with it being a hobby not enough spare time to do everything ๐
Post by Yogi on Jan 26, 2021 18:49:59 GMT 1
Not yet Sorry Its my fault I have got snowed under with a Koso clock housing project for somebody but Loganโs going to pick this project up hopefully tomorrow with a bit of help from me That the trouble with it being a hobby not enough spare time to do everything ๐ Keep me in mind for one please mate ๐
Post by alankelly on Jan 26, 2021 21:11:20 GMT 1
Thatโs better Would almost look original if it was orange ๐ Going to order a sample length of ASA and PETG and see what happens
Post by midlifecrisisrd on Jan 26, 2021 21:19:14 GMT 1
Nice ๐
Post by shaunthe2nd on Jan 26, 2021 21:49:04 GMT 1
Looking great Alan. is this how you celebrate your birthday?
Are you just printing the orange bit and re-using the original black centre?
Post by midlifecrisisrd on Jan 26, 2021 22:12:56 GMT 1
Oh, and Happy Birthday ๐
Post by alankelly on Jan 26, 2021 22:31:14 GMT 1
Looking great Alan. is this how you celebrate your birthday? Are you just printing the orange bit and re-using the original black centre? Hi Shaun Yes thinking of just doing the orange part and you keep the boss as it has the brass tube and that brass โweightโ and the assembly will then fit correctly and securely on the shaft If you are good a repairing clocks it should be easy enough to carefully swap the needle I know I have lots of irons in the fire so to speak at the mo (maybe too many๐๐) but will try to print a couple as its a quick print Stay safe all Al
Post by shaunthe2nd on Jan 26, 2021 22:45:17 GMT 1
Looking great Alan. is this how you celebrate your birthday? Are you just printing the orange bit and re-using the original black centre? Hi Shaun Yes I think of just doing the orange part and you keep the boss as it has the brass tube and that brass โweightโ and the assembly will then fit correctly and securely on the shaft If you are good a repairing clocks it should be easy enough to carefully swap the needle I know I have lots of irons in the fire so to speak at the mo (maybe too many๐๐) but will try to print a couple as its a quick print Stay safe all Al Alan, I'm happy to try one for fit for you if you looking for volunteers. I do find that sometimes they break at the boss where it is connected to the brass insert, sometimes you can re-glue this sometimes not, but the needle is a great spare to have in case the brittle needle snaps as it has a habit of doing. Great work.
Post by Gunny on Jan 26, 2021 23:16:05 GMT 1
Excellent work Alan
Post by alankelly on Jan 28, 2021 15:49:53 GMT 1
Speedo needle material has arrived ๐๐ Looks like Logan and me will be busy later tonight Best wishes Al
Post by midlifecrisisrd on Jan 28, 2021 16:03:48 GMT 1
Brilliant Al
I'll need some added to the YPVS horn cover and the lc clock idiot light bulb holder ๐
Post by abar121 on Feb 27, 2021 13:22:09 GMT 1
Hi Alan, I'd love a 31k ignition surround if you have any.
Cheers, Alan.
Post by alankelly on Feb 27, 2021 14:11:16 GMT 1
Hi Alan, I'd love a 31k ignition surround if you have any. Cheers, Alan. Pm sent
