Post by shergar on Jul 9, 2020 22:31:05 GMT 1
anyone have any idea why the rear of my 31k saddle is kicking up at the rear past the catches where it should sit flush with the plastic tail piece . i have had it recovered and brought it back to the bloke that did it and he says its defo not to tight as i thought the problem may have been . is this a common issue with the plastic base , is there any cure ? thanks
avb
andys vapour blasting
Post by avb on Jul 9, 2020 22:58:27 GMT 1
how was the fit before the new cover? as you say its normally overstretched covers causing the problem
Post by JonW on Jul 10, 2020 1:12:26 GMT 1
have a search, Steve (Midlife) talked about a fix for this a while back.
Post by marrcel on Jul 10, 2020 6:15:18 GMT 1
I have a crack in the plastic shel. This can lead to your situation. I repaired 20years ago with a peace of plastic parkered at the crack.
Post by midlifecrisisrd on Jul 10, 2020 10:40:32 GMT 1
It's too tight
If it fitted before and doesn't now the cover tension has bowed the base
I've sorted a couple by carefully heating the base with a hot air gun (careful as it will melt the base or cover) where it needs to bend then pushing it over a block to try and bend it back
