Post by stusco on Jul 8, 2020 7:52:17 GMT 1
What do you guy think about the colour of this oil ? it’s only done a few hundred miles im changing it to see if i can solve the clutch plates sticking together overnight
Oil
Jul 8, 2020 11:26:31 GMT 1
via mobile
Post by bernardo on Jul 8, 2020 11:26:31 GMT 1
You've got a bit of water in there
Post by headcoats on Jul 8, 2020 12:26:19 GMT 1
That's why a clear clutch window is useful , not just bling :-)
Oil
Jul 8, 2020 15:20:07 GMT 1
Post by chrisg on Jul 8, 2020 15:20:07 GMT 1
What do you guy think about the colour of this oil ? it’s only done a few hundred miles im changing it to see if i can solve the clutch plates sticking together overnight Possibly the O ring seal on the tube going to the water pump through the casing.
Oil
Jul 8, 2020 16:45:05 GMT 1
Post by steeley on Jul 8, 2020 16:45:05 GMT 1
Yep water in oil .
Oil
Jul 8, 2020 18:01:36 GMT 1
via mobile
Post by midlifecrisisrd on Jul 8, 2020 18:01:36 GMT 1
That may explain your clutch sticking
Had to pry plates apart on a clutch I just stripped. Frictions were rusted to the steels
Either water joint o ring or groove in water impeller
Oil
Jul 8, 2020 18:22:03 GMT 1
Post by stusco on Jul 8, 2020 18:22:03 GMT 1
Mmmm ill have to look at the impeller the o seal looked fine ,ive got one of those high flow alloy jobbies
Oil
Jul 8, 2020 18:29:47 GMT 1
via mobile
Post by midlifecrisisrd on Jul 8, 2020 18:29:47 GMT 1
A lot of them didn't have a hardened shaft (ooh err mrs) and the seal wore them out fast
Oil
Jul 8, 2020 19:05:02 GMT 1
Post by stusco on Jul 8, 2020 19:05:02 GMT 1
Thats what im now thinking
Post by arrow on Jul 9, 2020 6:28:01 GMT 1
Mmmm ill have to look at the impeller the o seal looked fine ,ive got one of those high flow alloy jobbies You didn't re-use the O ring did you? They should be replaced every time an assembly is disturbed. Cheap assurance.
Oil
Jul 9, 2020 7:45:36 GMT 1
Post by stusco on Jul 9, 2020 7:45:36 GMT 1
I always use new seals
Post by stusco on Jul 9, 2020 17:06:24 GMT 1
Looks like me pumps fooked And the seal as the spring came out with it So thats a pump,seal and bearing 😡
Oil
Jul 9, 2020 17:44:21 GMT 1
Post by headcoats on Jul 9, 2020 17:44:21 GMT 1
Was a genuine water pump seal
Oil
Jul 9, 2020 17:45:35 GMT 1
Post by stusco on Jul 9, 2020 17:45:35 GMT 1
Sorry i cant remember
Oil
Jul 9, 2020 17:53:06 GMT 1
dbgr likes this
Post by headcoats on Jul 9, 2020 17:53:06 GMT 1
I personally think that it's one of those seals that needs to be genuine like crank seals etc
Oil
Jul 9, 2020 17:56:29 GMT 1
via mobile
Post by midlifecrisisrd on Jul 9, 2020 17:56:29 GMT 1
Is the shaft grooved that bad?
Pic doesn't show it
May just be the seal failing
Oil
Jul 9, 2020 17:59:54 GMT 1
Post by stusco on Jul 9, 2020 17:59:54 GMT 1
Its a bad picture the groove is about half a mm deep
Oil
Jul 9, 2020 18:17:31 GMT 1
via mobile
Post by midlifecrisisrd on Jul 9, 2020 18:17:31 GMT 1
Bugger ☹
