Post by mholc123 on Jun 24, 2020 15:53:01 GMT 1
www.flickr.com/photos/189038300@N03/shares/S9P5U2I love the jacked up look of these bikes, I am using a NK Racing modified NC29 Swing arm and was wondering what the length of the shock absorber that other people have used when using the same Swinging Arm
Post by yamark on Jun 24, 2020 16:18:32 GMT 1
Hi Michael, I'm using an NC29 arm in the 700LC build. You get 3 options of ride height with NK Racings conversion, by using the rectangular blocks Nigel supplies.
I use a YSS shock- the one you can adjust the length of by 10mm. The model number is MZ366-315TRL-13-8-X
Hope that helps
Mark
Post by mholc123 on Jun 24, 2020 21:52:25 GMT 1
Thanks for your help Mark, I have followed your Four Cylinder build with interest and of course read about your triple build in PB, both exceptional and far above my capabilities. As I said I am looking for the Arse high look, but whilst there's a lot of information about RGV Swing Arm Equipped bikes there doesn't seem to be a lot about NC29, obviously there will be a point where if it set to high at the back the chain will slicing it's way through the Swinging Arm. I appreciate Nigel has built adjustability into the set up, so I'll probably have a play on the weekend with my standard (and very knackered) shock and see what I can get away with.
Thanks once again
Mike
