Post by headcoats on Jun 24, 2020 9:23:25 GMT 1
A lot of folks put 28mm carbs on their stock manifolds but can bigger carbs be fitted on there or do you really have to get bigger manifolds ?
Post by beardy on Jun 24, 2020 11:59:16 GMT 1
I’ve physically fitted 34mm Mikuni on power valve rubbers onto a 350lc. So they will go on.
Post by headcoats on Jun 24, 2020 12:08:36 GMT 1
Wow that is interesting
Could you see how they fitted inside , as in the manifolds were loose ?
Post by beardy on Jun 24, 2020 15:20:31 GMT 1
I did this back in the 80’s but am now running standard carbs. I just remember forcing them into the rubber inlet manifold. It sounds brutal but they did go in as advised by Stan Stephens at the time. I wasn’t running with air filters either. They obviously didn’t deform the manifolds as the standard carbs are still a snug fit. I’m assuming my memory isn’t playing tricks.
Post by bare on Jun 25, 2020 3:51:33 GMT 1
Real issue is that carbs Bigger than 28 mm PWKS... Foul the clutch linkages with their Float bowls. Some have fitted larger carbs and simply tilted them in the oen carb boots. And won races with that bodged setup... it clearly works, despite finger waglings. Other (usual) approach is to fit Pricey bespoke Billet intake manifolds
Post by beardy on Jun 25, 2020 7:52:01 GMT 1
Just for clarity on my answers. It was a 4lo engine.
Post by headcoats on Jun 25, 2020 8:16:10 GMT 1
So the custom manifolds are to move the carbs away from the clutch linkage , as well as having larger diameter rubbers for bigger carbs
Post by jessy03 on Jun 25, 2020 16:03:21 GMT 1
You can get larger manifolds that look like stock and they will except 35mm carbs, but you will need 6mm/10mm reed spacer to lift the carb over the clutch arm Jess
Post by jessy03 on Jun 25, 2020 16:09:29 GMT 1
Post by headcoats on Jun 25, 2020 16:36:49 GMT 1
Interesting Jessy J :-)
Are they manifolds they make for the Banshee ?
Post by jessy03 on Jun 25, 2020 16:40:33 GMT 1
Yes I ordered them from America a couple of years back.
Post by jessy03 on Jun 25, 2020 16:42:59 GMT 1
I was going to use them with a std airbox that’s why I got them, but I didn’t in the end, when down the pod filter route (yamarilia no room for airbox)
Jess
Post by muttsnuts on Jun 25, 2020 16:58:24 GMT 1
before squeezing larger carbs onto stock rubbers, measure the inside lip of the rubbers, the part that the carb spigot bumps up against, that will tell you how big a carb you can fit, anything bigger will be a waste of time as it will effectively be restricting the flow and cause turbulence
As Jessy says, you can buy the larger rubbers, not cheap if memory serves me right though
