Post by Dixie Dean on Jun 22, 2020 18:54:10 GMT 1
Hi any body help are the front foot rests supposed to spring up and which way do the springs go in ?
Post by Yogi on Jun 22, 2020 20:20:20 GMT 1
All the fronts spring up except the right hand on the lc2 which you lift up and down manually to clear the kickstarter
Post by midlifecrisisrd on Jun 22, 2020 20:30:36 GMT 1
I thought they sprung down 🤔
Post by Dixie Dean on Jun 22, 2020 20:36:48 GMT 1
Hi yogi if they spring down I have the spring in wrong any ideas pics would be great thanks
Post by Yogi on Jun 22, 2020 20:38:17 GMT 1
I thought they sprung down 🤔 Steve I meant they lift up on the spring but are held down 👍🤣 As I said in Deans other thread 😉
Post by Yogi on Jun 22, 2020 20:51:43 GMT 1
Lc2 front right F/N1 front ,you can just see the spring Matt 🧸
Post by Dixie Dean on Jun 22, 2020 20:59:11 GMT 1
Thanks guys
Post by JonW on Jun 24, 2020 0:30:26 GMT 1
All the fronts spring up except the right hand on the lc2 which you lift up and down manually to clear the kickstarter Its weird the LC2s have the 'spring up' on the starter side, but that was deleted for the F/N1 models. Same kicker, same size footrests and same footrest brackets etc.
Post by Deleted on Jun 24, 2020 4:09:57 GMT 1
Does that mean the kicker misses the right hand foot peg, Jon
Post by JonW on Jun 24, 2020 5:13:56 GMT 1
Ive actually just looked at the parts books and while the 85 has a 51L part number kicker, the 83 has a 29L version... The USA 84 has a 51L, hmm... I have a lot of 29L versions here, its cast into the kicker, but I need to check if i have some that say 51L, I cant recall any, hmm... unless the knuckle is different but i doubt that.
So yes, I think the 85 clears the early footpeg, and it should be a 51L 'branded' part... more after Ive had a look, Ive got LB looking at his stash as well.
Post by JonW on Jun 24, 2020 8:53:27 GMT 1
Ok, looked and all my kicker crank part say 29L. So I guess the knuckle is different on the 51L?
