Post by lukey1965 on Jun 18, 2020 11:17:04 GMT 1
Morning all.
I am looking at (possibly) a hose inline temperature sensor and small LCD gauge for a more accurate temperature readout and to overcome my current non working temp gauge.
Questions please:
What is the internal diameter of the hose ??
Which hose is best to fit to ??
Any suggestions please ?? (Looking at Koso)
Cheers, Paul
Post by 4l04ever on Jun 18, 2020 12:54:35 GMT 1
I would fix your own gauge as should be easier. What is the fault? Have you tried shorting the sensor wire to the ground, which should make the gauge go to max?
Post by lukey1965 on Jun 18, 2020 13:26:26 GMT 1
I would fix your own gauge as should be easier. What is the fault? Have you tried shorting the sensor wire to the ground, which should make the gauge go to max? Tried that, not working, have new (to me) working sensor as well. Thinking it is the gauge, so inline sensor with dash readout would be cheaper and, I believe, a more accurate measurement.
Post by JonW on Jun 18, 2020 13:35:24 GMT 1
A screw in sensor from a new unit might well fit in the head, I know the Koso one I had did.
Post by veg on Jun 18, 2020 13:40:40 GMT 1
Post by JonW on Jun 18, 2020 13:42:21 GMT 1
Yep thats the one I had and later butchered to fit in the LC tacho on my 421
Post by lukey1965 on Jun 18, 2020 13:45:53 GMT 1
A screw in sensor from a new unit might well fit in the head, I know the Koso one I had did. Looking at that as well. Do the 2 wire KOSO M12 temp sensors fit onto 4L0 ??
Post by lukey1965 on Jun 18, 2020 14:44:41 GMT 1
Looking at that or the round one (coin ??)
Post by lukey1965 on Jun 18, 2020 15:19:14 GMT 1
Yep thats the one I had and later butchered to fit in the LC tacho on my 421 Does the supplied sensor with this kit go into 4L0 head ??
Post by veg on Jun 18, 2020 15:39:10 GMT 1
Sorry I can’t say as my head is a tz one
Post by lukey1965 on Jun 18, 2020 16:04:21 GMT 1
Sorry I can’t say as my head is a tz one Thanks for your reply but was hoping Jonw could answer as he mentioned the kit you linked to was the one he had !!
Post by veg on Jun 18, 2020 16:08:33 GMT 1
He will pop a response on I’m sure he’s likely to be asleep as he is in Sydney (I’m mean the location before Matt or Steve say owt).
Post by lukey1965 on Jun 18, 2020 16:26:57 GMT 1
He will pop a response on I’m sure he’s likely to be asleep as he is in Sydney (I’m mean the location before Matt or Steve say owt). Haha !!
Post by Tobyjugs on Jun 18, 2020 16:37:30 GMT 1
A screw in sensor from a new unit might well fit in the head, I know the Koso one I had did. Looking at that as well. Do the 2 wire KOSO M12 temp sensors fit onto 4L0 ?? You can buy it from Koso to fit the 4LO cylinder head. I need to check but I think you need M10x1 threaded sensor
Post by lukey1965 on Jun 18, 2020 17:06:26 GMT 1
Looking at that as well. Do the 2 wire KOSO M12 temp sensors fit onto 4L0 ?? You can buy it from Koso to fit the 4LO cylinder head. I need to check but I think you need M10x1 threaded sensor Thanks. Look forward to your findings. Are they parallel threads for 4L0 ??
avb
andys vapour blasting
Post by avb on Jun 18, 2020 17:33:36 GMT 1
4LO are parallel PVs tapered
Post by lukey1965 on Jun 18, 2020 18:46:50 GMT 1
4LO are parallel PVs tapered Yes. I want to know if the koso temp sensors are parallel ??
avb
Post by avb on Jun 18, 2020 19:06:07 GMT 1
4LO are parallel PVs tapered Yes. I want to know if the koso temp sensors are parallel ?? ive got the koso on my F2 hybrid and they are tapered sorry for the confusion
Post by lukey1965 on Jun 18, 2020 19:15:50 GMT 1
Thanks, no problem.
I have tried a tapered one and didn't like it !!
Post by JonW on Jun 19, 2020 0:12:59 GMT 1
Yes its tapered, most modern ones are.
I think the kits from Koso can be ordered with diff sensors, not as an option but as a different kit etc.
Anyway, tapered thread with some sealant tape worked for me.
Post by Tobyjugs on Jun 19, 2020 8:31:05 GMT 1
I couldn't a fitting last night but think that it is straight. Will look over the weekend
Post by lukey1965 on Jun 19, 2020 10:38:42 GMT 1
Would anyone know the thread size of the standard LC temp sensor please ?? I think M10 or M12 ?? Thread pitch ??
Post by badger1 on Jun 19, 2020 11:33:07 GMT 1
They are the koso senders you get Iv had two koso temperature gauges both straight fitted into my 4l0/4l1 heads. These are not tapered.
Post by lukey1965 on Jun 19, 2020 11:48:06 GMT 1
Post by badger1 on Jun 19, 2020 14:10:53 GMT 1
Yep. I’ve got the rectangle one and used the twin reading one both had the same senders. I presume The round one is the same spec unit just round. These fitted my 4l0 heads ok.
Post by lukey1965 on Jun 19, 2020 14:41:23 GMT 1
Brilliant, many thanks Badger1. Where do you mount the rectangle gauge. Any piccies please ??
Post by badger1 on Jun 19, 2020 15:48:36 GMT 1
Post by badger1 on Jun 19, 2020 15:48:58 GMT 1
Post by lukey1965 on Jun 19, 2020 16:07:47 GMT 1
Wow that is neat !! I see Koso clock. Sorry to be a pain, what is your rev counter like please ??
Post by jon on Jun 19, 2020 16:49:21 GMT 1
4LO are parallel PVs tapered Yamaha made 3 YPVS heads embossed with Y1, Y2 and the later Y3. As far as I remember the early ones are straight M10x1 while the later Y3 is tapered M10x1 (or maybe even a similar pipe thread?). Someone may confirm one way or the other? Jon
