Post by alankelly on Jun 12, 2020 23:18:43 GMT 1
Hi all.
Just want to check that I am correct in thinking that if you turn the pilot air screw on a carb out (ccw) it leans the mixture and turning it in (cw) it richens the mixture
(Carbs on a Honda)
Stupid question I know but better to ask
Stay safe all
Best wishes Al
Post by mellow on Jun 12, 2020 23:27:22 GMT 1
depends if the screw is near the back side of the carburetor or near the front of the carburetor. If the screw is located near the back, it regulates how much air enters the circuit. If the screw is turned in, it reduces the amount of air and richens the mixture. If it is turned out, it opens the passage more and allows more air into the circuit which results in a lean mixture. If the screw is located near the front, it regulates fuel. The mixture will be leaner if it is screwed in and richer if screwed out
Post by alankelly on Jun 13, 2020 9:15:40 GMT 1
Thanks Mellow
Carbs are on a Honda and are at the back
Good to know there is a difference that I never knew about👍
You learn something new everyday here😁
Thanks again
Best wishes Al
