Post by steelerd on Jun 12, 2020 16:51:09 GMT 1
Hi guys, Contemplating whether to have these rebored or source a good used set to fit if they are good enough on a lower bore or then rebore them. RD250C removed the top end today because it sounded clacky since I got her (piston slap) Noticed they seem like they have been tuned spotted some knife edging to the transfers and noticed the exhaust port seems like a razor to touch not been chamfered. What's the max permissible overbore on a 250c? Not sure if the ports have been raised. So question is guys which way would you go? Cheers, Tom
Post by steelerd on Jun 12, 2020 17:59:19 GMT 1
Just to update bought a set on 0.25
Post by steeley on Jun 14, 2020 20:13:43 GMT 1
What ever you do with your new cylinders make sure the sharp edges of the ports are filed off .
