Post by zig on Jun 12, 2020 7:58:42 GMT 1
just wondering because I seen a post on the forum regarding a 2 stroke oil you should avoid or never run your rdlc on
I am about to run my new build on Castrol Power 1 , any problems with it???
ZiG
Post by mak595 on Jun 12, 2020 8:50:20 GMT 1
I run mine on castrol power 1, it's a modern oil from a good brand and easy to get as Halfords stock it
Post by midlifecrisisrd on Jun 12, 2020 8:57:03 GMT 1
Its a semi synthetic so you are fine
As said if halfords stock it then it ain't castor based
Post by mellow on Jun 12, 2020 9:39:33 GMT 1
I use and have always used Castrol Power1 Racing 2T and never had a problem with it. Yes Halfords sell it . It is fully synthetic
Post by stusco on Jun 12, 2020 10:15:36 GMT 1
And it smells quite nice ive got it in my RG
Post by arrow on Jun 12, 2020 12:37:32 GMT 1
Zig, I think you're getting a bit mixed up here, if I read you correctly. Castrol is a brand. They do make some Castor based products. Power one is not Castor based. Castor is a vegetable oil, made by pressing Castor beans. It is not a brand and can be produced by many companies. I checked all my spellings here as the words Castor and Castrol are very similar. HTH.
Post by chrisg on Jun 12, 2020 15:25:39 GMT 1
Post by midlifecrisisrd on Jun 12, 2020 15:28:10 GMT 1
Exol fully synth
£24 delivered for 5L 😁
Post by dusty350 on Jun 12, 2020 17:19:41 GMT 1
Watch Tesco's for Castrol Power 1. They often purge their stocks. Last 6 bottles I bought were £2.50 each Dusty
Post by chrisg on Jun 12, 2020 17:52:13 GMT 1
Post by chrisg on Jun 12, 2020 17:52:47 GMT 1
Exol fully synth £24 delivered for 5L 😁 Steve Thats a good price and delivered as well. Where was that from?
Post by arrow on Jun 12, 2020 17:58:07 GMT 1
Watch Tesco's for Castrol Power 1. They often purge their stocks. Last 6 bottles I bought were £2.50 each Dusty Blimey, £2.50! It would be less embarrassing to just nick it!
Post by midlifecrisisrd on Jun 12, 2020 17:58:43 GMT 1
Post by copper99 on Jun 12, 2020 19:46:30 GMT 1
Watch Tesco's for Castrol Power 1. They often purge their stocks. Last 6 bottles I bought were £2.50 each Dusty That was a few years ago now, its no longer stocked by them ...unless you bought some recently?
Post by mak595 on Jun 12, 2020 19:57:02 GMT 1
I use my Halfords trade card so get power 1 a couple of quid cheaper than the great unwashed 🤣🤣
Post by 123 on Jun 12, 2020 20:24:40 GMT 1
I use power 1 find it very good clean burning no build up on rings
Post by mellow on Jun 12, 2020 23:21:51 GMT 1
This is not the fully synthetic one. It's semi i believe . power 1 racing 2T is fully Synthetic
Post by mellow on Jun 12, 2020 23:21:59 GMT 1
Post by chrisg on Jun 13, 2020 19:21:34 GMT 1
This is not the fully synthetic one. It's semi i believe . power 1 racing 2T is fully Synthetic Sneaky, didn't spot that. Power 1 (Racing) Fully synth. Power 1, semi.
Post by arrow on Jun 13, 2020 19:24:22 GMT 1
Its still the top spec, JASO FD.
Post by 4l04ever on Jun 13, 2020 23:29:42 GMT 1
I use the Exol fully synthetic oil. You can get 20 litres delivered for about £65 off eBay. Heads cleaned up with just a wipe after a few thousand miles of use.
Post by flames on Jun 17, 2020 18:02:04 GMT 1
Years ago I had an mtx 125 that had been run on Castrol r40. This is castor based I believe and made it smell like a speedway bike.i loved it and never had an issue with the oil itself although I have heard plenty that didn't like it. However while rebuilding after a circlip broke, I somehow managed to fit the carb from the other mtx 125 I was building by mistake, which was not run on r40. Even tho there was only residue in the carb it reacted and turned to jelly, starving the engine of oil, with the inevitable seizure . 1 newly rebored engine destroyed. This is why people say never mix them.
Post by zig on Jun 17, 2020 18:48:56 GMT 1
Zig, I think you're getting a bit mixed up here, if I read you correctly. Castrol is a brand. They do make some Castor based products. Power one is not Castor based. Castor is a vegetable oil, made by pressing Castor beans. It is not a brand and can be produced by many companies. I checked all my spellings here as the words Castor and Castrol are very similar. HTH. no I recently seen a post about the 'castor' based oil and know of it's problems but as I have a new build with 'your pump' I just want to get it right from the outset and continue to run it on the one oil that I have chosen but get some feedback from the guy's on here that it's a good choice Cheers Gary ZiG
Post by arrow on Jun 17, 2020 18:57:26 GMT 1
I think its only the pure mineral based 2-stroke oil that Castrol make is the only one thats not top spec. The other two mentioned are top spec.
