Post by chrisg on Jul 8, 2020 18:56:09 GMT 1
Any good powder coater will protect the threaded holes/inserts in the frame, however I always put old bolts in all the threads to prevent or minimise any media that may contaminate the threads. Once back home, run a tap through the threads before assembly.
2taol
Post by 2taol on Jul 8, 2020 19:54:45 GMT 1
good work so far! nice to see another restoration with a view to keeping it standard.
Post by nokturnal on Jul 13, 2020 11:16:48 GMT 1
Coming along!
Gord
Post by Gord on Jul 18, 2020 21:02:15 GMT 1
Received my new pistons. First over size. These ones are coated.
jay
2 stroke or not 2 stroke
Post by jay on Jul 19, 2020 0:21:03 GMT 1
Great work coming along nicely Regards Jay
Gord
Post by Gord on Jul 19, 2020 0:52:25 GMT 1
Great work coming along nicely Regards Jay Thank you
Gord
Post by Gord on Jul 22, 2020 17:55:09 GMT 1
Got the engine completely apart now. I have to say this part scares me. The reason is if I screw something up putting it back together it’s a lot of work to get it apart again. Like has been mentioned though it’s a relatively simple engine. Cases and some other parts are now out for vapour blasting. Carefully put all the parts in order Other parts for cleaning
Post by hudtm60 on Jul 23, 2020 6:01:52 GMT 1
Post by lcmarky on Jul 24, 2020 8:44:06 GMT 1
Interesting read and you’re looking good.
An ultrasonic cleaner will have those cabs looking fresh in 5 mins.
I’m also rebuilding and upgrading everting but haven’t quite got the knack of the picture posting.
Try to ensure your frame number is still readable through the powder coat.
Post by shaunthe2nd on Jul 24, 2020 9:02:18 GMT 1
Agree with comment above, but will take more than 5 mins in ultrasonic, but think it was meant as a figure of speech. When you do the carbs, strip out all the brass parts and remove the big brass ball before you put into the cleaner. I usually put each in for min 2 off 20 min cleaning cycles. I clean the brass bits in a separate cleaning cycle.
Great thread and good luck with it, looks like you had a good starting point.
Post by lcmarky on Jul 24, 2020 11:32:50 GMT 1
Agree with comment above, but will take more than 5 mins in ultrasonic, but think it was meant as a figure of speech. When you do the carbs, strip out all the brass parts and remove the big brass ball before you put into the cleaner. I usually put each in for min 2 off 20 min cleaning cycles. I clean the brass bits in a separate cleaning cycle. Great thread and good luck with it, looks like you had a good starting point. .yes indeed it was aimed at the principle that a US cleaner is a great almost miraculous thing!
Gord
Post by Gord on Jul 24, 2020 14:12:38 GMT 1
Thanks, and yes Dusty’s posts are an amazing help. Haven’t heard of Arrow for the oil pump before....I’ll check into it.
Gord
Post by Gord on Jul 24, 2020 14:13:32 GMT 1
Interesting read and you’re looking good. An ultrasonic cleaner will have those cabs looking fresh in 5 mins. I’m also rebuilding and upgrading everting but haven’t quite got the knack of the picture posting. Try to ensure your frame number is still readable through the powder coat. I’ve been doing all the posting on my phone - way easier for me to post pics.
Gord
Post by Gord on Jul 25, 2020 20:52:02 GMT 1
Before and after pics of the parts I had cleaned with vapour blasting. We plugged all the hole on the carbs to clean up the outside. Wasn’t sure how the fork legs would look but I think they’ll be pretty nice, same with the foot peg brackets
Gord
Post by Gord on Jul 30, 2020 3:23:34 GMT 1
Working on recreating my mangled VIN sticker with date code. I’ve written to Yamaha to see if they can date it for me. My other bike is SN 000782 and was manufactured in 12/80 so I’m estimating 300-400 bikes a month roughly puts 407 at 11/80....maybe 10/80. Anyone know? I’ve also written to VJMC but don’t think the North American club dates bikes. Getting close to the right font I think. Needs to be a bit darker though and bold face is too much.
Post by JonW on Jul 30, 2020 5:15:40 GMT 1
Good work Gord.
How about changing the 'O' to a '0' (zero) as that might help the font a bit?
Post by shaunthe2nd on Jul 30, 2020 8:23:02 GMT 1
Nice thread and great work thanks for sharing.
Gord
Post by Gord on Jul 30, 2020 11:57:17 GMT 1
Good work Gord. How about changing the 'O' to a '0' (zero) as that might help the font a bit? Great idea Jon, I'll try that. The original is definitely a little narrower than the one I've got here.
Post by arrow on Jul 30, 2020 20:06:52 GMT 1
Nice work Gord.
Gord
Post by Gord on Aug 25, 2020 16:45:54 GMT 1
I’ve got it as close as it’s going to get. Going to have it printed on a metallic vinyl to try and match the original colour. Funny thing is the font I ended up using is called DIN alternate
2taol
Post by 2taol on Aug 25, 2020 18:21:27 GMT 1
what program are you using to layout the sticker?
the best program would be Adobe InDesign, the text can be "squashed" and "pulled" to create better sizing.
Gord
Post by Gord on Aug 25, 2020 18:31:28 GMT 1
what program are you using to layout the sticker? the best program would be Adobe InDesign, the text can be "squashed" and "pulled" to create better sizing. I just used Pages on a Mac
Gord
Post by Gord on Aug 25, 2020 18:34:05 GMT 1
The first new part was installed today! Yeah I’m officially on the road to putting it back together. Got this from HVC cycle
Gord
Post by Gord on Aug 25, 2020 19:33:07 GMT 1
Was hoping to re-use the seat foam - got the old cover off today and the foam is starting to break down. Any suggestions on where to order new foam from?
Post by flames on Aug 25, 2020 19:57:30 GMT 1
Norbo sells the seat foam and covers in his shop. If you pm him he is also selling a load of seats. He had some good tidy looking ones. Worth asking, very reasonable price aswell considering how much foam and covers cost. I bought a re covered one from him , hopefully be her this week.
Gord
Post by Gord on Aug 26, 2020 19:45:56 GMT 1
Picking these up today from the printer. Not bad eh!
Gord
Post by Gord on Sept 5, 2020 2:54:36 GMT 1
New seat foam arrived today. It was interesting speaking with the Phil from P and K Classic Bikes who is the only person in the world who makes molded seats for the LC.
Post by tacky1 on Sept 5, 2020 3:19:55 GMT 1
I have one of his foams on my last LC build. Fitted perfect 👍
Post by JonW on Sept 5, 2020 7:17:57 GMT 1
New seat foam arrived today. It was interesting speaking with the Phil from P and K Classic Bikes who is the only person in the world who makes molded seats for the LC. Er... Webike (from Japan) sell foams too, made by Daytona. I have the Daytona seat foam and cover on my 251LC. I also have a P&K foam on my resto LC. Quite different foams, but both good. The sticker came out superbly Gord, well done!
Gord
Post by Gord on Sept 5, 2020 18:39:57 GMT 1
New seat foam arrived today. It was interesting speaking with the Phil from P and K Classic Bikes who is the only person in the world who makes molded seats for the LC. Er... Webike (from Japan) sell foams too, made by Daytona. I have the Daytona seat foam and cover on my 251LC. I also have a P&K foam on my resto LC. Quite different foams, but both good. The sticker came out superbly Gord, well done! Thanks Jon!
