Gord
Post by Gord on May 31, 2020 14:47:44 GMT 1
Post by dusty350 on May 31, 2020 19:16:49 GMT 1
Looking good so far Gord Looks like it's had replacement clutch plates at some point Dusty
Gord
Post by Gord on May 31, 2020 19:35:07 GMT 1
Looking good so far Gord Looks like it's had replacement clutch plates at some point Dusty Thanks Dusty. I’ll measure them and probably put new ones in anyway. I got this in a box of spares with the bike, not even sure it’s from an RD?
Post by dusty350 on May 31, 2020 20:03:29 GMT 1
That's a Pv (powervalve) pressure plate Dusty
Post by steelerd on May 31, 2020 20:59:55 GMT 1
Looking good!
Gord
Post by Gord on Jun 1, 2020 22:50:41 GMT 1
Pistons out, and cans off. I’m thinking it’s never had the top end done by the 000’s on the piston? Cylinder doesn’t look scored to me. Pretty sure James Bond’s brother had this one at some point. Not sure what that means? These studs look like a no-win situation to me:
Post by JonW on Jun 1, 2020 23:56:56 GMT 1
Thats a polished well used bore, its going to need a rebore I would think.
Those studs would clean up i would think.
Gord
Post by Gord on Jun 2, 2020 2:24:33 GMT 1
Thats a polished well used bore, its going to need a rebore I would think. Those studs would clean up i would think. I hope they do - I’m afraid to try and remove them.
Post by JonW on Jun 2, 2020 2:35:54 GMT 1
give em a brush with a small wire brush and some WD40 and see what they look like, else have the whole bottom end vapour blasted.
Gord
Post by Gord on Jun 2, 2020 2:36:49 GMT 1
Removed the rear wheel. The one that came in the bike has a dent on the rim. I got a spare with it so I’m going to try and clean up the rust in the drum and use the wheel that isn’t dinged up. Next to start cleaning up the subframe while I wait for tools to continue taking the engine apart. Flat spot on this side of the rim. Spare wheel that I hope to clean up.
Post by JonW on Jun 2, 2020 3:08:35 GMT 1
You could knock that dent out for sure. Spin it on a balancer or even an axle held in a vice and see if the whole wheel is out first tho as that would write it off.
Post by dusty350 on Jun 2, 2020 7:32:47 GMT 1
If you get the cases vapour blasted those studs will come up like new. It's a great process for cleaning up the cases, and allows you to see any damage or areas of concern, much better. It's a non aggressive process, so wont affect bearing surfaces, and you end up with cases that look like they have had a nice coat of silver paint ! It also "seals" the surface metal so it's easier to keep clean. The media is very fine and is delivered in high pressure water which sort of "buffs" the surface of the ali. Lots of info on the forum about it Dusty
Gord
Post by Gord on Jun 12, 2020 1:47:31 GMT 1
Started cleaning the paint off the pipes while waiting for tools for the clutch and flywheel. Can these silences be re-packed?
Post by JonW on Jun 12, 2020 3:58:45 GMT 1
Yes, twist round some new wadding.
Gord
Post by Gord on Jun 16, 2020 0:11:56 GMT 1
Post by JonW on Jun 16, 2020 5:18:17 GMT 1
They look great Gord!
Post by Dangerous on Jun 16, 2020 7:07:52 GMT 1
Looking good gord👍
fabiostar
the older i get the faster i was.
Post by fabiostar on Jun 16, 2020 15:29:02 GMT 1
like the look of those pipes, what paint did you use on them?
Post by chrisg on Jun 16, 2020 16:17:41 GMT 1
like the look of those pipes, what paint did you use on them? +1 for paint make and type. Looks factory finish.
Post by Jethro5 on Jun 17, 2020 0:48:24 GMT 1
I removed the wadding from my baffles after reading some posts on here. Doesn’t seem to make much difference to noise.
Gord
Post by Gord on Jun 20, 2020 16:24:24 GMT 1
like the look of those pipes, what paint did you use on them? Thanks so much. I used a spray bomb 3 coats primer, 4 coats flat black (it only comes in flat) and 3 coats clear which gave it the sheen.
Post by veg on Jun 20, 2020 18:56:08 GMT 1
Guessing it’s an import? Mine had done 25000 klicks and was on std bore they tend to be well looked after and not messed with.
Gord
Post by Gord on Jun 20, 2020 19:10:31 GMT 1
Guessing it’s an import? Mine had done 25000 klicks and was on std bore they tend to be well looked after and not messed with. It's a Canadian Bike (I'm in Canada). Mine's got over 30k on it
Post by veg on Jun 20, 2020 19:14:28 GMT 1
It seems it’s only Uk bikes that take a pounding. Looks 👍
Gord
Post by Gord on Jun 20, 2020 19:16:19 GMT 1
It seems it’s only Uk bikes that take a pounding. Looks 👍 Thanks - it’s getting harder and harder to find them here. Good ones are rare.
Gord
Post by Gord on Jun 28, 2020 22:04:35 GMT 1
Cases split and inspected. Not sure about the half rings. Should there be 2 halves on each bearing? I have a couple bearings that only have one.
Post by chrisg on Jun 28, 2020 22:13:44 GMT 1
Hi Gord, Gearbox looks very good. Only 1-off 1/2 moon ring fitted in each gear line per engine. Its coming on a treat. I have the exact bike/colour and am going through a full refurb. My bike is nearly built back up. Top tip, take lots of pics, harness, cable routing etc.. you will be glad you did. I find that am searching out pics to see harness routing, cables etc.
Gord
Post by Gord on Jun 28, 2020 22:27:17 GMT 1
Hi Gord, Gearbox looks very good. Only 1-off 1/2 moon ring fitted in each gear line per engine. Its coming on a treat. I have the exact bike/colour and am going through a full refurb. My bike is nearly built back up. Top tip, take lots of pics, harness, cable routing etc.. you will be glad you did. I find that am searching out pics to see harness routing, cables etc. Thanks Chris, was worried I dropped them! Yes I've been taking lots of pics. Let me know if you need a pic of a wiring route. I have fair amount of them.
Gord
Post by Gord on Jul 8, 2020 15:37:09 GMT 1
Final bath last night - my parts washer #3 crapped out. I don’t think it likes Varsol so I had to make do
Gord
Post by Gord on Jul 8, 2020 15:38:29 GMT 1
Off to the powder coater today. Very excited to be almost done taking things apart.
