zalle
Post by zalle on May 21, 2020 21:13:40 GMT 1
Hi, I need to install a GIVI case in the back. Any idea how to do it? Any examples?
Thanks
Post by hoist1 on May 21, 2020 21:32:44 GMT 1
What’s it for, rack will prob have to be custom made.
Post by hoist1 on May 22, 2020 7:15:06 GMT 1
And if you get stuck for a box I have a stack of them in the loft.
Post by earthman on May 22, 2020 8:44:38 GMT 1
Does the Givi box have a mounting plate with it? Do you have the LC luggage rack already fitted on the bike??
zalle
Post by zalle on May 22, 2020 15:54:24 GMT 1
Hi guys, My RD is standard, no luggage rack, just the chrome handle. I'm thinking about custom making a couple of metal stripes, with two holes that will attach to the chrome handle bolts (I guess the handle comes off), and then they turn around 90 degrees, and a bit down, so I can attach a mounting plate with a couple of holes in each metal stripe. Here is a terrible drawing of what I'm thinking about, hope you understand it.
Or is there something ready to attach to the RD?
<img src=" " alt="" style="max-width:100%;">
Post by hoist1 on May 22, 2020 17:06:14 GMT 1
Will have to fit in place of grab rail , may not be that strong, easier to use tank bag.
Post by copper99 on May 22, 2020 19:45:54 GMT 1
You should be able to mount it straight to the grab rail using the "W" shaped fittings supplied with the baseplate, this has been on a friends or friends blade for years...
Post by museumman on Jun 2, 2020 2:31:36 GMT 1
Post by earthman on Jun 2, 2020 7:30:35 GMT 1
Now that rack doesn't look too out of place or ugly unlike the one for the 250/350LC that I've seen.
Post by KevtheRev on Jun 3, 2020 11:33:30 GMT 1
The Givi racks always break . And the weight of rack and box will affect handling , esp on such a light bike . Do you need a box all the time ? Some of the couriers I used to work with simply bungeed the box onto the pillion seat when using it , and whipped it off when not needed . You'd have to put some small bolts through the plastic box for the bungees to hook onto . HTH .
