Post by oldbritguy on May 21, 2020 15:31:47 GMT 1
Anyone used these or another type of fitting on LC radiators. This or another solution for fitting the plastic guard as it is a bit neat for getting a nut and washer in when fitted Cheers John
Post by stusco on May 21, 2020 15:57:12 GMT 1
I bought a chinese rad it didn’t have any nuts but the holes were in the rightful place so i used rivet nuts perfect fit
Post by JonW on May 22, 2020 0:31:49 GMT 1
used them on things before, but not this problem. Alloy versions are much easier to compress than the steel ones, sounds obvious now ive told you but ive seen people struggle with stainless when alloy would do and be easier.
Post by headcoats on May 22, 2020 7:42:49 GMT 1
I used them on my kr1s swingarm to mount a chain slider
Post by earthman on May 22, 2020 8:39:10 GMT 1
I've never had to use them but they do sound like they could be the answer to fix many things. Are you guys buying them singular or have you found a box/kit containing different sizes? Any links to suppliers of such kits?
Post by steeley on May 22, 2020 9:38:07 GMT 1
I've never had to use them but they do sound like they could be the answer to fix many things. Are you guys buying them singular or have you found a box/kit containing different sizes? Any links to suppliers of such kits? Hi ,machine mart sells ali riv nuts in different sizes . They also sell a kit .
Post by headcoats on May 22, 2020 10:08:53 GMT 1
I used M5 alloy rivnuts and I found there was a fine line between compressing the rivet and actually ripping the thread out of the rivnut, but I am crap LOL
Post by oldbritguy on May 22, 2020 10:17:18 GMT 1
Cheers guys
I have ordered some M5 ones from ebay and will have a go and see how they work out
I agree with jonw that it would be a bit tricky compressing steel fittings on those flimsy alloy tangs on the rad when alloy ones will suffice. After all they are only securing a plastic cover.
I have looked at various tools and I think I could make something up which will do the job but with a bit of care so I dont rip the thread out of the thing (cheers headcoats for the warning) when fitting. Will post some pics when they arrive and hopefully work
John
Post by muttsnuts on May 22, 2020 10:29:59 GMT 1
I use them all the time for various repairs/hybrid builds etc, you need to practice a little at first to find the correct setting for each size rivert nut and different material thicknesses, but once you have the settings, its a peice of wee wee after that, worth doing a few practices on scrap metal, saves stripping the threads as some do by being "over" enthusiastic lets say !
Post by oldbritguy on May 22, 2020 10:35:13 GMT 1
Haha good advice Dave I only need 4 for the rad grill but I have ordered 20 to experiment with as I expect a few errors to begin with. They were only a couple of pounds so cheap enough I am that "over enthusiastic" individual you have referred to John
Post by midlifecrisisrd on May 22, 2020 11:19:53 GMT 1
This is a dilemma I'm having at the moment
On the TR frame I'll need some fixings for things like undertray, elec panel mounts Tec
Do I get brackets welded on as I build or use rivnuts 🤔
Oh the dilemmas
Post by 4l04ever on May 22, 2020 12:53:15 GMT 1
I would do a practice one using a torque wrench so you can find the safe amount of torque to use.
Post by JonW on May 22, 2020 13:31:30 GMT 1
I bought a kit on ebay about 10years back, thats how I got mine.
Post by Deleted on May 22, 2020 15:49:44 GMT 1
If you get a good set of Riv nut pliers, and read the instructions of how much to compress the riv nut, the pliers will have a scale on them that tells you how much you have compressed them, that way you don't rip the mandrel out of the nut
The rive nut just needs to grip the substrate and not spin
Use knurled ones they offer a better grip on the hole they go into
Post by steeley on May 22, 2020 20:38:06 GMT 1
I used M5 alloy rivnuts and I found there was a fine line between compressing the rivet and actually ripping the thread out of the rivnut, but I am crap LOL I had a job years ago when i was fitting a lot of riv nuts and yes ali ones were my last choice because of the chance of pulling the thread .I had access to a couple of insert tools oh er mrs . One was like a pop rivet gun and the other had a screw thread in the main body of the tool which was changeable depending what insert was being fitted and you had more control over the crush .
Post by raven13 on May 22, 2020 21:09:17 GMT 1
A set of rivnut pliers and a compliment of various sizes "nuts" are a must in any bike builders tool box. I use them personally on my builds and we use them in the garage all the time.
Post by midlifecrisisrd on May 22, 2020 21:09:30 GMT 1
I used M5 alloy rivnuts and I found there was a fine line between compressing the rivet and actually ripping the thread out of the rivnut, but I am crap LOL I had a job years ago when i was fitting a lot of riv nuts and yes ali ones were my last choice because of the chance of pulling the thread .I had access to a couple of insert tools oh er mrs . One was like a pop rivet gun and the other had a screw thread in the main body of the tool which was changeable depending what insert was being fitted and you had more control over the crush . Same here Think they called it a clinch nut tool Like a pop riveted but had a changeable rod with a knob on one end to screw in and out and a thread on the end Inserts were stainless Steve
Post by JonW on May 23, 2020 0:27:18 GMT 1
I had a job years ago when i was fitting a lot of riv nuts and yes ali ones were my last choice because of the chance of pulling the thread .I had access to a couple of insert tools oh er mrs . One was like a pop rivet gun and the other had a screw thread in the main body of the tool which was changeable depending what insert was being fitted and you had more control over the crush . Same here Think they called it a clinch nut tool Like a pop riveted but had a changeable rod with a knob on one end to screw in and out and a thread on the end Inserts were stainless Steve Yes the tool with my set is like that as well, Ive never pulled a thread with it. If anything its almost too hard to squeeze really, maybe i need to work out more lol
Post by raven13 on May 23, 2020 20:49:41 GMT 1
Same here Think they called it a clinch nut tool Like a pop riveted but had a changeable rod with a knob on one end to screw in and out and a thread on the end Inserts were stainless Steve Yes the tool with my set is like that as well, Ive never pulled a thread with it. If anything its almost too hard to squeeze really, maybe i need to work out more lol I always set the tool, then back it off a touch to make starting the pull on the insert easier, give it a short pull. then set it properly and finish the insert
paulls
Post by paulls on Mar 27, 2021 21:54:09 GMT 1
They make excellent replacements in a situation where you would normally use a nut and bolt through a metal collar . Simply push in a riv nut with collar at rear and just use a bolt . Sort of a semi captive nut.
