Post by mille1000 on May 1, 2020 20:27:49 GMT 1
Hello My Lc tyres were brand new 10 years ago so it’s time to change them what are people using? Shame as they have only done about 10 miles !!!
Post by 4l04ever on May 1, 2020 20:28:45 GMT 1
BT45s for me :-)
colbox
Post by colbox on May 1, 2020 20:40:08 GMT 1
Road Rider for me
Post by peter007 on May 1, 2020 20:41:10 GMT 1
I’ve deliberated for weeks mate and I eventually went with Avon roadriders mk11 90x90 x18 front and 100x90x18 Rear and an I pleased I did the bike handles Sublime now . I got them from I’m sure tyretech tradng and they were the cheapest by miles at £133 delivered miles cheaper than anyone else google Avon roadrider 11 tyre packages and then phone them on they’re number as the discount on the webpage isn’t correct better to order them on the phone they come next day if you order before 11am I think hope this helps pete
motty
Post by motty on May 1, 2020 21:07:45 GMT 1
BT45 for me on my both my bikes. BITD we changed the tyres several times a year, nowadays, mine, like yours, tend to last getting on for a decade 😟
Post by damiensk on May 1, 2020 21:16:47 GMT 1
did the same, brand new BT45's, dont even think i did 10 mtrs on them, 10 years ago. think bidgestone have now brought out BT46's? thats what i wil be going for!!!
Post by Norbo on May 1, 2020 21:30:47 GMT 1
Avon roadriders MKL11 for me the rubbers the same as the Bts they handle the same and last the same i just like the pattern more
Post by veg on May 1, 2020 21:57:45 GMT 1
Rear should be 80 profile not 90.
Post by donkeychomp on May 1, 2020 21:59:20 GMT 1
BT45s for me.
Post by 4l04ever on May 1, 2020 22:02:10 GMT 1
The BT45s are supposed to have slightly better grip but slightly shorter life than the Road Riders.
Post by Deleted on May 1, 2020 22:25:22 GMT 1
Post by peddrotzr on May 2, 2020 10:06:56 GMT 1
Continental Classic Attack
Used in the Yamaha Pro-Am revival a few years ago. loads of grip Brilliant tyres. Hope that helps.
Post by earthman on May 2, 2020 10:47:10 GMT 1
Good thread this, my LC came with Metzlers , plenty of tread on them but I can't wait to try something else.
Post by shaunthe2nd on May 2, 2020 10:49:57 GMT 1
If you are only doing 1 mile per year it probably doesn't matter!
Post by rich on May 2, 2020 11:06:47 GMT 1
Rear should be 80 profile not 90. Yep, I always fit 90/90 18 front and 110/80 18 rear.
Post by Tobyjugs on May 3, 2020 2:49:33 GMT 1
BT 45's for me. Nicely scrubbed in front tyre.
Post by mattybeckett on May 3, 2020 4:38:42 GMT 1
Roadriders for me 👌
Post by nokturnal on Jun 30, 2020 11:42:53 GMT 1
Used in the Yamaha Pro-Am revival a few years ago. loads of grip Brilliant tyres. Hope that helps. Is there a separate “race” compound? Like the Avons?
Post by flames on Jun 30, 2020 12:45:17 GMT 1
Rear should be 80 profile not 90. Yep, I always fit 90/90 18 front and 110/80 18 rear. I've always fitted 110 90s on mine. Thought they were 80's as standard but that's what were fitted when I bought it. Still on road runners. Getting on for 20 years old now. Were ok in dry, but loved to spin in the wet. I always liked Bridgestones when I had my blade but like norbo I prefer the pattern on the riders, so that's probably what I will go for next
Post by bodger on Jun 30, 2020 13:02:06 GMT 1
Standard sizes used to be 3.00 x 18 front and 3.50 x18 rear old sizes but I’ve always ran a 90/90 or 100/90 front and a 110/90 or 120/90 rear.and if it’s good enough for pro-am it’s good enough for me 😁
Post by mak595 on Jun 30, 2020 13:22:30 GMT 1
Avon roadriders on mine
Post by peddrotzr on Jun 30, 2020 17:41:27 GMT 1
Is there a separate “race” compound? Like the Avons?[/quote] I have just spoken to the UK importer :- "The Caucus is of radial construction designed specifically for older Classic bikes, combined with modern compound giving superb grip. Continental only made one compound as their wasn't any need for a race compound".
If you want more information :- www.conti-bike.co.uk/category/tyres/classic/I hope that helps. Best regards
haj
Post by haj on Jul 1, 2020 14:06:29 GMT 1
Standard sizes used to be 3.00 x 18 front and 3.50 x18 rear old sizes but I’ve always ran a 90/90 or 100/90 front and a 110/90 or 120/90 rear.and if it’s good enough for pro-am it’s good enough for me 😁 What pressures do you run in 100/90 front + 120/90 rear? I was crazy enough to fit those sizes on my LC2 and it wobbles a bit on the front with 32psi front /40psi rear.. I'm aware there could be other reasons than tyres and pressures..
Post by flames on Jul 1, 2020 15:17:04 GMT 1
I think I ran them pressures when I were young . 90/90 front 110/90 rear. I was about 8.5stone sopping wet and the thing slapped like a bitch over white lines and bumps. Handled better 2 up but would still slap fairly. I put it down to me not being heavy enough to make the suspension work, but I wander if the pressure was too high in the rear as well. I've got different shock and weigh another 4stone now and don't seem to have an issue.
Post by stanlc7189 on Jul 1, 2020 22:56:53 GMT 1
I have BT45s fitted. I decided to fit a 120/80 rear rather than a 110/80. It transforms the handling making the front end feel much more planted under power. I run 30 psi front and 32 psi rear.
Post by damiensk on Jul 20, 2020 16:18:17 GMT 1
just had a set of BT46's fitted, £186, balanced, etc and old ones disposed of. not sure how better they are from the 45's?
haj
Post by haj on Aug 18, 2020 15:22:25 GMT 1
Just as a follow up, when I run 40 psi front, 42psi rear on my 100/90 front + 120/90 rear.. The wobble seems to stop Haven't tried lower pressures yet. I'm pretty heavy at 125kg's. Bike is an LC2 running a YSS shock at default setting and stock suspension front.
freddie19
Member is Online
Post by freddie19 on Aug 18, 2020 18:29:51 GMT 1
I've always run BT45 100/90 front and 120/80 rear. 120/90 rear tyre is too tall.
Bike handles great and so much more sure footed than the skinny std sizes!
Even the road tests at the time said the tyres were undersized for the rims!
Give them a try..... you'll love them!😁
Post by tacky1 on Aug 18, 2020 20:56:01 GMT 1
BT45 here as well on multiple bikes and grip great
Post by 29davyt on Aug 21, 2020 8:25:39 GMT 1
I’ll be going for the Roadriders once I get round to ordering some, on purely looks alone they really suit the bike ( IMO ),, seems to be a bit of variation in what sizes people are running ?? Does the difference between a 110/80 rear or a 110 /90 rear effect the handling or gearing on the bike ( 90 section will obviously have a greater circumference )
