peterb
Post by peterb on Apr 20, 2020 1:59:19 GMT 1
hi can some one post or give direction to a site for 4lo wiring diagram not pdf thanks
Post by shaunthe2nd on Apr 20, 2020 9:24:45 GMT 1
There you go.
Post by earthman on Apr 20, 2020 10:49:27 GMT 1
I like that style of diagram, makes things very clear what with the little pictures of each item, someone has gone to a lot of effort but the style of clocks are wrong. Lol
Post by Gitram on Apr 20, 2020 12:30:25 GMT 1
aye, that's nice. I have a A3 size copy of the one in the haynes manual which is ok but when the local print shop reopens i'll get a big print of this (framed and hung on the garage wall)..
cheers marti
Post by 4l04ever on Apr 20, 2020 13:50:52 GMT 1
I have a hi-res scan of the Haynes Manual diagram in colour I can email you. Just drop me a PM with your email address.
Post by jackjabba on Apr 20, 2020 20:06:39 GMT 1
There you go. Shaun have you got a better resolution image of this diagram? Cheers Jack
Post by shaunthe2nd on Apr 20, 2020 20:09:21 GMT 1
There you go. Shaun have you got a better resolution image of this diagram? Cheers Jack The version I have is a 2Mb picture. If you PM me your email addy i will ping it to you if that helps.
Post by badger69 on Sept 18, 2021 13:22:23 GMT 1
I have a hi-res scan of the Haynes Manual diagram in colour I can email you. Just drop me a PM with your email address. Hi great idea, can you please tell me what colour is the wire from the temperature gauge to the multi connection then to the tempeture sensor on the head, as I'm trying to trace and find this wire on my LC, if I can't find it can this be bought and fitted, thanks mate, take care stay safe.
Post by reedpete on Sept 18, 2021 13:33:03 GMT 1
If you PM me your email addy i will ping it to you if that helps. Shaun, I’ll do that too if you don’t mind!
Post by badger69 on Sept 18, 2021 13:48:24 GMT 1
If you PM me your email addy i will ping it to you if that helps. Shaun, I’ll do that too if you don’t mind! badgerjum7@hotmail.co.uk thanks mate.
Post by badger69 on Sept 18, 2021 14:17:08 GMT 1
If you PM me your email addy i will ping it to you if that helps. Shaun, I’ll do that too if you don’t mind! Hi again could you tell me where the temperature cable comes out of the loom on its own, should I be able to see where it's came from with only the tank off, because I've seen pictures of the whole loom and the wire comes out from the side of it on its own, thanks
Post by badger69 on Sept 18, 2021 14:30:53 GMT 1
