Post by yamark on Nov 22, 2020 20:59:14 GMT 1
Brilliant work, as always Steve. I think you can get away with painting the plastic parts on the engine. I've never seen a rear mudguard, number plate holder or rad guard painted, that look top draw. Great build for "leftovers" mate
Post by midlifecrisisrd on Nov 22, 2020 21:17:51 GMT 1
Brilliant work, as always Steve. I think you can get away with painting the plastic parts on the engine. I've never seen a rear mudguard, number plate holder or rad guard painted, that look top draw. Great build for "leftovers" mate Cheers Mark If it was still summer I'd probably have made an attempt on painting the left case but it's cold and damp now and I can't be bothered degreasing the crud off the inside . I found 3 when I was looking in the garage rafters 🤣 You are right on the other plastics though, not worth the effort to just not look quite right I have a muddy and a reg plate holder to cut so nothing will be seen on them lol Still got some "nice" bits to fit that are hanging around the garage 😎 Need to play Russian roulette with radiators. I have 3 but I'm sure one has a weep Steve
Post by shaunthe2nd on Nov 22, 2020 21:18:21 GMT 1
My next job is the fuel tap too. Will follow your tip thanks as my project came with various tap bits and a repair kit. Not sure if its Tourmax though but will give it ago. I'm quite familiar with 4L0 taps but not these vacuum ones so will be a school day for me.
Post by midlifecrisisrd on Nov 22, 2020 21:39:40 GMT 1
My next job is the fuel tap too. Will follow your tip thanks as my project came with various tap bits and a repair kit. Not sure if its Tourmax though but will give it ago. I'm quite familiar with 4L0 taps but not these vacuum ones so will be a school day for me. One bit of advice when doing a ypvs tap When you take the plate off that holds the rotating valve in AND the actual rotating bit mark both of them which way was up as both can go back in 2 ways If you get them wrong it either throws out where the stops are or whether it turns clockwise or anticlockwise from the 12 o clock position Steve
Post by midlifecrisisrd on Nov 26, 2020 14:49:36 GMT 1
Grabbed an hour in the shed today Managed to connect the throttle cable and throttle tube along with a pair of genuine grips Also cut a rear muddy down and got it fitted Steve
Post by midlifecrisisrd on Nov 26, 2020 20:02:13 GMT 1
Oh and no I'm not colour blind. I know the bar ends are blue
I bought them in 2013 for my TSX but never fitted them so they were "leftover" 😁
Post by shaunthe2nd on Nov 26, 2020 20:37:37 GMT 1
Is that a clue to your paint scheme?
Post by midlifecrisisrd on Nov 26, 2020 21:10:52 GMT 1
Is that a clue to your paint scheme? Afraid not but I've always fancied doing a candy blue one It will be in standard early lc2 black scheme. There is a pic of the tank on page 3 Steve
Post by JonW on Nov 26, 2020 23:22:33 GMT 1
That anodising would come off with a gentle blast if you didnt want the blue. Ive some natty blue RGV steering top nuts that Ive done that too. I got em cheap at some point lol
Post by midlifecrisisrd on Nov 26, 2020 23:32:00 GMT 1
That anodising would come off with a gentle blast if you didnt want the blue. Ive some natty blue RGV steering top nuts that Ive done that too. I got em cheap at some point lol Dis think about it for a nano second but to be honest they don't offend me enough to bother 🙂 Steve
avb
andys vapour blasting
Post by avb on Nov 26, 2020 23:53:26 GMT 1
That anodising would come off with a gentle blast if you didnt want the blue. Ive some natty blue RGV steering top nuts that Ive done that too. I got em cheap at some point lol Dis think about it for a nano second but to be honest they don't offend me enough to bother 🙂 Steve theyre plain wrong steve id blast for nowt if it helps
Post by JonW on Nov 27, 2020 0:09:04 GMT 1
Dis think about it for a nano second but to be honest they don't offend me enough to bother 🙂 Steve theyre plain wrong steve id blast for nowt if it helps This! Thanks AVB!
Post by midlifecrisisrd on Nov 30, 2020 17:21:33 GMT 1
Chain fitted now so sprocket nut tightened along with the flywheel nut Steve
Post by stusco on Nov 30, 2020 17:25:07 GMT 1
Oven cleaner will have them bare alloy in a few seconds
Post by midlifecrisisrd on Nov 30, 2020 17:29:48 GMT 1
Oven cleaner will have them bare alloy in a few seconds Very true but I can't be 4rsed at the moment lol. Maybe when it's done I've still got your vac bag folded up in my garage 😬 Steve
Post by stusco on Nov 30, 2020 17:45:41 GMT 1
Dont worry about the vac bag im fiddling with the lc and my rg is mia 😫
Post by midlifecrisisrd on Nov 30, 2020 17:49:13 GMT 1
Dont worry about the vac bag im fiddling with the lc and my rg is mia 😫 Jeez,,you still not got that back 😱 Steve
Post by midlifecrisisrd on Nov 30, 2020 21:03:53 GMT 1
New side case fitted Had a little issue with the bottom bolt beside the gear change That section of the case was missing so I had a donor piece from a scrap case welded in and it was slightly off so a little filing to sort it Steve
Post by sidney81 on Nov 30, 2020 21:21:03 GMT 1
Oh and no I'm not colour blind. I know the bar ends are blue I bought them in 2013 for my TSX but never fitted them so they were "leftover" 😁 Steve hi ,the adjustable lever's you have on do they fit straight in the stock master cylinder and clutch perch ? I might need some I have small hands 😂,Chris
Post by midlifecrisisrd on Nov 30, 2020 21:36:19 GMT 1
Oh and no I'm not colour blind. I know the bar ends are blue I bought them in 2013 for my TSX but never fitted them so they were "leftover" 😁 Steve hi ,the adjustable lever's you have on do they fit straight in the stock master cylinder and clutch perch ? I might need some I have small hands 😂,Chris I had a few levers so not quite sure which brake lever I used I know I had an fzs1000 lever but I think this was one of the others that fit the LC/YPVS master cylinder. Is it a WR or something like that The clutch lever is a Fazer one which needs a couple of small spacers. One each side to fill the space in the Lc2 perch May have a pair of stumpy ones and the spacers 🤔 Steve
Post by sidney81 on Nov 30, 2020 22:06:11 GMT 1
hi ,the adjustable lever's you have on do they fit straight in the stock master cylinder and clutch perch ? I might need some I have small hands 😂,Chris I had a few levers so not quite sure which brake lever I used I know I had an fzs1000 lever but I think this was one of the others that fit the LC/YPVS master cylinder. Is it a WR or something like that The clutch lever is a Fazer one which needs a couple of small spacers. One each side to fill the space in the Lc2 perch May have a pair of stumpy ones and the spacers 🤔 Steve I've just seen a few pairs on e bay some cheep ones might be worth a go especially at that price ,I will have a think thanks Steve 👍
Post by midlifecrisisrd on Dec 2, 2020 20:43:11 GMT 1
Fitted the FZR chain guard and a reg plate holder Steve
Post by midlifecrisisrd on Dec 3, 2020 12:13:53 GMT 1
Gear change fitted with new washers/circlip and a titanium rod I'd forgot about The end of the gear lever had the usual bit of rash so dressed it back and painted it Also adjusted the oil pump cable and fitted the refurbed cover Steve
Post by midlifecrisisrd on Dec 4, 2020 20:31:01 GMT 1
Few small jobs tonight Painted a radiator and cleaned out the coolant expansion tank so bolted that on. Removed the centre stand (it would be ok left on but the swinger has bobbins so not needed) Then fitted the exhaust stubs ready for the pipes to go on Hopefully get the rad on tomorrow Steve
Post by Yogi on Dec 6, 2020 9:35:14 GMT 1
Coming along nicely now mate 👌
Post by midlifecrisisrd on Dec 6, 2020 16:43:36 GMT 1
20 minutes with the heater on before I went out and the shed is toasty 😊 Fitted the exhausts and then nipped up the bolts I've messed around and managed to get the side stand so it just grazed the pipe so I'll trim down the spring mushroom and notch the fork at the pivot end like I did on my last build so the stand sits higher Very happy with them, they are Mutts/Alonze pipes in stainless Steve
Post by arrdy350 on Dec 6, 2020 16:54:57 GMT 1
They look very nice. What exhausts are they?
Post by midlifecrisisrd on Dec 6, 2020 17:40:40 GMT 1
They look very nice. What exhausts are they? Bought from Muttsnuts on here All round performance pipes designed by him and fabricated by Alonze customs Steve
Post by midlifecrisisrd on Dec 6, 2020 17:45:35 GMT 1
Did a deal on some parts with Kenny for some nice stubby alloy silencers Gaskets from 4l04ever May sound a little fruity 😀 Steve
Post by mouse on Dec 6, 2020 18:10:36 GMT 1
This is a really lovely build, big fan of the wheel colour too
Mouse
