Post by midlifecrisisrd on Sept 27, 2020 18:14:01 GMT 1
Struggling to find anything that looks like ' leftovers' on this build......do you plan to do a ' load of ol' scrap' build in the future? Perhaps we might find something that looks 2nd hand even if it's only been used once.😁 I know, I must apologise I went too far trying the newly plated brake pedal 🤣🤣🤣 Steve
Post by flames on Sept 27, 2020 18:24:10 GMT 1
This is an awesome build regardless of how you came about the part's. Certainly shows mere mortals like myself , the standards to which they should be built.👍
Post by midlifecrisisrd on Sept 30, 2020 15:20:05 GMT 1
Prepped the tie bars for fitting
Post by flames on Sept 30, 2020 16:04:20 GMT 1
Prepped the tie bars for fitting Have you drilled and tapped the towel?
Post by midlifecrisisrd on Sept 30, 2020 16:32:06 GMT 1
Prepped the tie bars for fitting Have you drilled and tapped the towel? It's the new finish on the engine Thought beige Terry towelling would look good 😂 Steve
2taol
Post by 2taol on Sept 30, 2020 18:51:40 GMT 1
will look good with the white-wall tires !
Post by midlifecrisisrd on Oct 1, 2020 18:37:45 GMT 1
What is it with switchgear
Took the 4 half that were still in original paint (they weren't even that bad) in a tub of Methyl Chloride for 4 hours
Takes the first one out, it's all bubbled and the paint falls off
The next 3, not the slightest bit soft 😡
Now gave up on the DCM and filled a jar with some industrial paint stripper and left them in it in disgust 😤
Post by midlifecrisisrd on Nov 4, 2020 19:40:55 GMT 1
Gave up and sent the switchgear to Andy to vapour blast them Now painted and decals fitted Steve
avb
andys vapour blasting
Post by avb on Nov 4, 2020 20:04:04 GMT 1
they look great steve
Post by midlifecrisisrd on Nov 10, 2020 10:58:24 GMT 1
Switchgear fitted
Post by arrdy350 on Nov 10, 2020 19:15:06 GMT 1
Look great 👍
Post by sidney81 on Nov 10, 2020 22:14:40 GMT 1
Lovely work 😊
Post by JonW on Nov 10, 2020 23:27:07 GMT 1
Look good, with the proviso that I always think the decals for these are like they were printed in BOLD when they shouldnt have been. Ahh well, gotta use what we got and make it look nice.
Post by midlifecrisisrd on Nov 11, 2020 9:51:28 GMT 1
Look good, with the proviso that I always think the decals for these are like they were printed in BOLD when they shouldnt have been. Ahh well, gotta use what we got and make it look nice. This is true but NOS ones have dried up I did find a cheap NOS RH one last week and then found a NOS LH from a different model that I could have robbed the cases off but that would have been £150 and not in the spirit of this "leftovers" build I think I'm finally winning the battle of keeping buying stuff lol In saying that I've just bought a 31k tank, an LC tacho and a kidney clock top case in the last week 😭 In fairness the clock bits are to help make up sets with all the spares I have and my excuse for the tank was "when will I ever find another really good one" Anyway, must go and see what's new on ebay 😂 Steve
Post by JonW on Nov 11, 2020 11:16:54 GMT 1
Im totally with you Steve. I bought nos switches for my 47x after I had refurbed a set, so the refurbed ones will go on my F2... like you ive spent waaay too much on parts over the years and there comes a time when you have to use stuff up
Post by midlifecrisisrd on Nov 11, 2020 16:50:06 GMT 1
Few more little little bits done Fitted a new stator wiring grommet. Would have been rude not to considering the wiring was full of taped up dry twist joints Soldered the joints, heat shrink tubing fitted then retaped with seld amalgamating tape then fitted Stuck new plugs in Then fitted the coil along with new plug caps Then fitted a pair of genuine pv cables Also measured the chain run and worked out I need a 9mm offset front sprocket so I'll order that Steve
Post by midlifecrisisrd on Nov 14, 2020 14:51:40 GMT 1
I'd been toying with buying new plastic engine covers but given the cheapest clutch disc is £40, the oil pump cover is £67 and the stator/sprocket cover is £99 it's not in the spirit of the build to buy all 3 so I'll see what I can do I had a Yam disc that had no rash but had a very sticky reflective sticker on it which I eventually got off by soaking in cellulose thinners then polished with Autosol and some polish. Think it's perfectly usable now so I won't paint it as any imperfections are outweighed by the risk of reactions if I apply paint The best oil pump cover I had wasn't bad. Just a little scuff on the round section as usual and a couple of other scratches Degreased, 1k filler, sanded then wiped with acetone ready for painting I'm still undecided on the stator case. No matter how good you get the paint it doesn't look as good as a new one 🤔 Steve
Post by midlifecrisisrd on Nov 14, 2020 14:53:31 GMT 1
That clutch case disc can't be bad, that's the reflection of my other bike in it 🤣
Post by arrdy350 on Nov 14, 2020 16:25:25 GMT 1
Few more little little bits done Fitted a new stator wiring grommet. Would have been rude not to considering the wiring was full of taped up dry twist joints Soldered the joints, heat shrink tubing fitted then retaped with seld amalgamating tape then fitted Stuck new plugs in Then fitted the coil along with new plug caps Then fitted a pair of genuine pv cables Also measured the chain run and worked out I need a 9mm offset front sprocket so I'll order that Steve Very nice what is the hole for in the bottom of the caseing next the stator?
Post by midlifecrisisrd on Nov 14, 2020 16:36:38 GMT 1
Few more little little bits done Fitted a new stator wiring grommet. Would have been rude not to considering the wiring was full of taped up dry twist joints Soldered the joints, heat shrink tubing fitted then retaped with seld amalgamating tape then fitted Stuck new plugs in Then fitted the coil along with new plug caps Then fitted a pair of genuine pv cables Also measured the chain run and worked out I need a 9mm offset front sprocket so I'll order that Steve Very nice what is the hole for in the bottom of the caseing next the stator? If it's the hole I think you mean it's for a dowels to locate the outer casing Steve
Post by arrdy350 on Nov 14, 2020 17:00:40 GMT 1
Sorry ment the hole under the neutral switch cover. I couldn't remember what it was called.
Post by midlifecrisisrd on Nov 14, 2020 17:06:07 GMT 1
Sorry ment the hole under the neutral switch cover. I couldn't remember what it was called. God only knows 🤣 Some cases have it, some don't. Another RD mystery lol Steve
Post by arrdy350 on Nov 14, 2020 17:17:02 GMT 1
Sorry ment the hole under the neutral switch cover. I couldn't remember what it was called. God only knows 🤣 Some cases have it, some don't. Another RD mystery lol Steve I had seen some with it and without. My one doesn't have it. Strange 🤔
Post by midlifecrisisrd on Nov 14, 2020 17:17:24 GMT 1
Oil pump cover done 😁 As for the engine case... ... f*ck it, I've bought a NOS one 🤣 Spent an hour cleaning and trying to polish 2 unpainted ones I had but they don't look good enough when beside the newly painted engine Steve
Post by JonW on Nov 17, 2020 5:55:37 GMT 1
God only knows 🤣 Some cases have it, some don't. Another RD mystery lol Steve I had seen some with it and without. My one doesn't have it. Strange 🤔 Early ones do I think, later are solid.
Post by midlifecrisisrd on Nov 17, 2020 9:43:35 GMT 1
I had seen some with it and without. My one doesn't have it. Strange 🤔 Early ones do I think, later are solid. That's what I originally thought too then I found a set that didn't fit that theory Can't remember if it was late with the hole or early solid but made me think "that theory is f*cked" 😆 Maybe their stock rotation wasn't good lol Steve
Post by shaunthe2nd on Nov 17, 2020 9:54:48 GMT 1
Oil pump cover done 😁 As for the engine case... ... f*ck it, I've bought a NOS one 🤣 Spent an hour cleaning and trying to polish 2 unpainted ones I had but they don't look good enough when beside the newly painted engine Steve I've done a few 4L0 plastic engine covers with some success, but didn't realise the 31k type are much harder to get a decent finish. No doubt I will find out soon. Great thread by the way.
Post by midlifecrisisrd on Nov 20, 2020 14:14:43 GMT 1
Carbs cleaned to within an inch of their lives, new fuel valves fitted and on the bike now complete with cable and tubing The rubber seals at the cable elbow were split so I've used a new pair of aircooled rubbers which cover rusty elbows 😁 Steve
Post by midlifecrisisrd on Nov 20, 2020 14:23:22 GMT 1
Next was the fuel tap In the spirit of the "leftovers" I decided to refurb the tap with a Tourmax kit rather than spending £85 for a new tap Had a couple of old taps so built 1 good one out the 2 Vacuum side of the tap working fine now and turns freely Some say they still don't work and still pass fuel but I've always found as long as meticulously clean and nothing corroded they work fine Did find the main reason most don't stop the fuel when the engine isn't running, check the pitting on the rear of the tap valve. This allows fuel to flow past the prime position hole so bypasses the vacuum diaphram Steve
Post by lc350pete on Nov 22, 2020 11:36:30 GMT 1
Looking excellent nice finish on the engine
