Post by midlifecrisisrd on Aug 12, 2020 13:17:40 GMT 1
Top job  Is it hard to get gen gaskets? Also where did you find NOS pistons and rings? The pistons are NOS but unfortunately not genuine Yam They are an old set of Jap TKR's hence the discoloration on them but for £30 a pair with rings I can't complain You do get NOS genuine ones on ebay but pricey. If you look up the banshee part numbers you can still buy genuine ones from Yamaha Main difference is no expander under the bottom ring and rings are different I think As for gaskets the base ones from Yam are £24 each now and a head gasket is £55 No way worth it but if you can wait you can get them from this guy which is where mine are from www.ebay.co.uk/itm/PRE-ORDER-30-DAYS-RD350-YPVS-31K-1UA-1WT-48H-GENUINE-HEAD-BLOCK-GASKET-SET/383629893695?hash=item59521fa03f:g:R2gAAOSwT6Zdg-RoNever had import charge from him either Steve
Post by arrdy350 on Aug 12, 2020 13:42:02 GMT 1
Ok thanks 👍 seen parts for the ypvs for sale on the net and I think to myself (HOW MUCH?). I have got a gasket set but it is not yam,so I am not really sure about it. Also what did you use to seal the top and bottom cases together?
Thanks Arrdy
Post by midlifecrisisrd on Aug 12, 2020 15:01:24 GMT 1
Ok thanks 👍 seen parts for the ypvs for sale on the net and I think to myself (HOW MUCH?). I have got a gasket set but it is not yam,so I am not really sure about it. Also what did you use to seal the top and bottom cases together? Thanks Arrdy Pattern gaskets are ok other than I'd use a genuine head gasket and genuine crank, oil pump and water pump seals Use threebond 1184 or 1215 to join the cases Steve
Post by arrdy350 on Aug 12, 2020 15:46:07 GMT 1
Thanks 👍 I will have to add a gen oil pump and waterpump seal to ever growing list of parts 😥 before I put mine back together.
Post by flames on Aug 12, 2020 17:10:04 GMT 1
Thanks 👍 I will have to add a gen oil pump and waterpump seal to ever growing list of parts 😥 before I put mine back together. Wise move, do it right 1st time and you shouldn't have any issues. Do like I did ( now on 3rd re build) and suddenly gen yam parts don't seem so expensive 1st time round. Cutting corners and ' that will be ok ' to get bike done quicker ends in 3 times the cost and even more time off the road getting things sorted. Hindsight is a wonderful thing , take advantage of other people's , it saves a lot of regret.
Post by arrdy350 on Aug 12, 2020 18:28:43 GMT 1
This will be the first time I have ever rebuild an engine before. Hopefully I do it right the first time  Just trying to clean the carbon off the exhaust ports at mo thats fun (NOT) . And then I will start a build thread. Yep Hindsight is a wounderful thing
Post by flames on Aug 12, 2020 18:59:10 GMT 1
Check out the build threads. Dusty posted a good one. They are very easy to work on, but equally easy to miss the small details like retainer clips. Take your time, keep checking your manual / threads and take pics as you go......you will question yourself about whether you fitted that circlip or retainer....but not until the cases are bolted up or the top end is on. Helps to have pics to check. If in doubt about something , ask the question on here. Plenty of very knowledgeable helpful people that know what they're talking about.
Post by midlifecrisisrd on Aug 13, 2020 17:24:43 GMT 1
Head on and torqued up
Post by Yogi on Aug 13, 2020 17:28:49 GMT 1
Get back to work 😱I ain’t got time to do anything while the suns shining 🥵
Post by midlifecrisisrd on Aug 13, 2020 17:32:49 GMT 1
Get back to work 😱I ain’t got time to do anything while the suns shining 🥵 This furlough is hell 😁 Was told 2 days ago instead of last notice that it was to 31/8 it's going to be Sept too Today I've cut the grass, treated a wasp nest, done some housework, been to the garage and did a bit on the TR and this build and been to the engineer to get spacers made Run off my feet here 🤣 Steve
Post by Yogi on Aug 13, 2020 17:48:21 GMT 1
Get back to work 😱I ain’t got time to do anything while the suns shining 🥵 This furlough is hell 😁 Was told 2 days ago instead of last notice that it was to 31/8 it's going to be Sept too Today I've cut the grass, treated a wasp nest, done some housework, been to the garage and did a bit on the TR and this build and been to the engineer to get spacers made Run off my feet here 🤣 Steve Bloody hell mate,,I feel sorry for ya now 🥴
Post by flames on Aug 13, 2020 22:38:25 GMT 1
Head on and torqued up  I have never known 'left overs' to look so good.
Post by midlifecrisisrd on Aug 15, 2020 20:31:46 GMT 1
Moved the spoked hybrid out the workshop to get ready to sell so brought the leftovers bike round Steve
Post by flames on Aug 15, 2020 21:26:30 GMT 1
Looking really good.
Post by midlifecrisisrd on Aug 25, 2020 16:11:11 GMT 1
Bought some rose joints and high tensile bolts so brake torque arm now sorted Steve
Post by midlifecrisisrd on Aug 25, 2020 18:42:02 GMT 1
Collected the tank from the paintshop 😁
Post by midlifecrisisrd on Aug 27, 2020 13:26:54 GMT 1
Got my finger out my butt and got back to the engine Fitted the reeds and new inlet rubbers then got the thermostat fitted and the rear water fitting
Post by midlifecrisisrd on Aug 27, 2020 13:33:57 GMT 1
Fitted the first pipe of my cheapo Chinese hoses £19 posted 😁 They actually fit better and more snugly than the red GPI set I used on the last build Balance pipe and replated clips fitted Had no more deep acorn nuts for the barrel studs (spending as little extra as possible to stick with the leftovers theme) so used replated nuts then fitted cut down threaded rod protectors 😀 Steve
Post by midlifecrisisrd on Aug 27, 2020 16:58:48 GMT 1
Primaries and baskets on along with idler gear
Post by midlifecrisisrd on Sept 1, 2020 18:02:17 GMT 1
Been doing some bits and bobs. I'll post pics when paint has dried.
Clutch kit hasn't turned up yet 🧐
Did pressure test it and it failed. Luckily just on the left balance pipe joint.
I had used replated original clips but a pair of jubilee clips later it held pressure 😀
Torqued up the clutch centre bolt ready for when the kit turns up. Bought one of the EBC drc kits for the first time as I had no steels so fingers crossed
Also had a new LC lockset in my Ebay basket for 2 weeks now and nearly hit the button so many times but knew I had some new mismatched lock parts
Had a dig in the shed and found a NOS tzr250 iggy switch (B type key), a used LC iggy switch (C key) a new gen fuel cap (C type key) and a box of used seat locks
Now the fuel cap is a right faf so I decided that was the keys I'd use.
Iggy switch first. Stripped the tzr and LC switches and p1ssed about for ages and stripped another 2 seat locks for parts to finally get the C barrel to work with the fuel cap key. Fitted it in the TZR barrel and lock base but with the LC wiring and contacts
Then got a seat lock barrel that would take the C key. Think it was an F lock and worked through the tumblers I had left and managed to get it matched to the fuel key again
Just waiting on the seat latch bodies drying to finally assemble them 😁
Post by midlifecrisisrd on Sept 1, 2020 18:30:21 GMT 1
Little pic showing the lock barrel with the key tabs you need to change to get the other key to fit. 5 tabs, 9 types of tab 😅 The last tab is what locates the barrel in the lock to stop it pulling out with the key The springs can be little buggers 😆 Just a few spares left 😬 Steve
Post by midlifecrisisrd on Sept 1, 2020 18:31:10 GMT 1
Post by flames on Sept 1, 2020 19:59:55 GMT 1
Been doing some bits and bobs. I'll post pics when paint has dried. Clutch kit hasn't turned up yet 🧐 Did pressure test it and it failed. Luckily just on the left balance pipe joint. I had used replated original clips but a pair of jubilee clips later it held pressure 😀 Torqued up the clutch centre bolt ready for when the kit turns up. Bought one of the EBC drc kits for the first time as I had no steels so fingers crossed Also had a new LC lockset in my Ebay basket for 2 weeks now and nearly hit the button so many times but knew I had some new mismatched lock parts Had a dig in the shed and found a NOS tzr250 iggy switch (B type key), a used LC iggy switch (C key) a new gen fuel cap (C type key) and a box of used seat locks Now the fuel cap is a right faf so I decided that was the keys I'd use. Iggy switch first. Stripped the tzr and LC switches and p1ssed about for ages and stripped another 2 seat locks for parts to finally get the C barrel to work with the fuel cap key. Fitted it in the TZR barrel and lock base but with the LC wiring and contacts Then got a seat lock barrel that would take the C key. Think it was an F lock and worked through the tumblers I had left and managed to get it matched to the fuel key again Just waiting on the seat latch bodies drying to finally assemble them 😁 Steve I was with you all the way until the b lock c lock f lock thing? I've been in a headlock a time or 2 in my yoof.
Post by arrdy350 on Sept 1, 2020 20:01:46 GMT 1
Looking good
Post by Yogi on Sept 1, 2020 20:14:53 GMT 1
Did you mean to leave the outer ring of the damper in the hanger 🥴
Post by midlifecrisisrd on Sept 1, 2020 20:38:50 GMT 1
Did you mean to leave the outer ring of the damper in the hanger 🥴 Yep 😁 I'm going to try using LC hanger bungs and wanted them to be extra tight Steve
Post by midlifecrisisrd on Sept 2, 2020 10:44:55 GMT 1
Some replated bits Refitted and job done Steve
Post by midlifecrisisrd on Sept 2, 2020 11:44:27 GMT 1
Hangers baked for 30 mins then fitted NOS front and rear pegs 😎 Steve
Post by flames on Sept 2, 2020 13:14:01 GMT 1
Hangers baked for 30 mins then fitted NOS front and rear pegs 😎 Steve  Have you got any 'leftovers' on this build that aren't NOS or not rebuilt with NOS parts? I have the odd new part for mine that look 2nd hand compared to your leftovers!!!
2taol
Post by 2taol on Sept 2, 2020 20:37:27 GMT 1
coming along nicely, lovely results
