Post by dave1w on May 10, 2020 10:05:09 GMT 1
Did you say you have spare clutch arms?
Post by midlifecrisisrd on May 10, 2020 10:32:11 GMT 1
Did you say you have spare clutch arms? I do have 2 but I was going to cut them and make an extended one Sorry, Steve
Post by midlifecrisisrd on May 20, 2020 12:17:41 GMT 1
Whats that in my back pocket, oh its just that "spare" Yss shock that was kicking about, Ma erse Oh! What's this hiding under this box I'd forgot about
Post by midlifecrisisrd on May 20, 2020 12:20:38 GMT 1
Would you believe it? It's only an Ignitech! Amazing what you find lying around π€£π€£π€£ Steve
Post by veg on May 20, 2020 16:53:00 GMT 1
Oh this old thing, nah had it for ages love
Post by Yogi on May 20, 2020 16:58:18 GMT 1
Yeah. Yeah ,,the box it came in is under the carbs in the bin ππ€£π€£π€£π€£
Post by oldbritguy on May 20, 2020 20:40:28 GMT 1
I wish I could find goodies like that when rummaging around in the garage All I ever find is worn out bits I should have binned years ago If you find any more feel free to give me a shout John
Post by midlifecrisisrd on May 22, 2020 12:02:37 GMT 1
Did a couple of little jobs Fitted longer bolts on the dog bones to allow Nyloc nuts on them Couldn't find high tensile for the link arm arm bolt so as it's M14 I thought A4 should do the job
Post by midlifecrisisrd on May 22, 2020 12:05:16 GMT 1
Then as I'd removed the centre stand on my other build I decided to fit it to this bike Don't know if I'll leave it on, will wait till it's further on and see how it looks It has stand bobbins anyway but thought the stand will help at the building stage
Post by midlifecrisisrd on May 22, 2020 12:06:37 GMT 1
And finally in preparation for fitting the rear wheel to work out spacers I made up the chain adjusters with some stainless threaded rod Steve
Post by midlifecrisisrd on May 22, 2020 20:18:38 GMT 1
Can't believe no one noticed the tie bar bolts were through from the wrong side π
That's what happens when your working upside down π€£
Post by midlifecrisisrd on May 29, 2020 14:19:12 GMT 1
Got 3mm milled off the FZR caliper bracket and the spacer between the bracket and wheel made 3mm longer so the wheel is now in π Steve
Post by midlifecrisisrd on Jun 12, 2020 14:39:34 GMT 1
Turned the bike the right way up now so fitted the forks and top yoke 2002 Fazer 600 forks and a Fazer top yoke modded to use a ypvs ignition switch and steering lock Steve
Post by oldbritguy on Jun 12, 2020 17:10:59 GMT 1
Looking grand Steve Did the top yoke need much modification to take the lc ignition and lock? You have made it look quite straight forward (as usual)
Post by rattler on Jun 12, 2020 17:43:49 GMT 1
Love these builds
Post by midlifecrisisrd on Jun 12, 2020 18:07:05 GMT 1
Looking grand Steve Did the top yoke need much modification to take the lc ignition and lock? You have made it look quite straight forward (as usual) It's quite simple. Its easier on an f/n frame as the lock tab is lower The switch mounts on the yoke are the right spacing but m8 and too long You just cut them down a bit to make the lock the right height to hit the tab on the frame You then drill the holes deeper and tap them with m6 threads On the ignition surround on the top yoke you need to bring it out a bit on the lc2 to get it to clear the switch body Bottom yoke is quite easy too. Lock stop tab on frame simply need another bit welded on the end as the tabs are further out The stem is too long by 20mm All that needs done is the top bearing area, the castle nut threads and the top yoke thread need machined/cut 20mm further down and 20mm cut off the end The yokes are cheap as chips. You can even use a fazer bottom yoke and an xjr400 top yoke like my other build Steve
Post by midlifecrisisrd on Jun 12, 2020 18:15:37 GMT 1
Front wheel in now Standard Fazer front wheel and discs. The fazer uses a digital Speedo but instead of triggering via a sensor on the drivetrain there is a drive with a cable giving a pulse signal to the Speedo Luckily a ypvs Speedo tab washer, retainer and oil seal go straight in the wheel Then an rd400 Speedo drive with a slight mod to the housing where the drive locates onto the fork leg fits the wheel and even is the right width so is a straight fit with the Fazer spindle and spacer. Also fitted a pair of refurbed tdm 850 front calipers with stainless bolts Steve
Post by midlifecrisisrd on Jun 12, 2020 19:02:14 GMT 1
Fazer risers fitted and a pair of renthal 758's Steve
Post by midlifecrisisrd on Jun 12, 2020 19:03:22 GMT 1
New rear master fitted and a refurbed F2 rear caliper Steve
Post by Yogi on Jun 12, 2020 19:17:15 GMT 1
F2 rear master? Thought youβd throw an r6 brembo in ,,there as cheap as a rebuild kit
Looking good π
Post by midlifecrisisrd on Jun 12, 2020 19:27:56 GMT 1
F2 rear master? Thought youβd throw an r6 brembo in ,,there as cheap as a rebuild kit Looking good π Cheers bud. I normally would (did that on my last build) but I think I paid under Β£30 for it in a badly listed eBay add π Steve
Post by midlifecrisisrd on Jun 12, 2020 19:29:36 GMT 1
I've edited it now as made an ass of it
The caliper was f2 refurbed π
Been a long day
Post by midlifecrisisrd on Aug 6, 2020 18:33:58 GMT 1
No this build hasn't had a Covid related death π¬ Built the mate's LC motor and had to do some maintenance on my rental house. Standard bore barrels painted and Pv's fitted with new bushes and seals Hopefully get the top end on next week Steve
Post by Yogi on Aug 6, 2020 19:18:41 GMT 1
Donβt forget the valve retainers ππlooking good
Post by midlifecrisisrd on Aug 6, 2020 19:44:08 GMT 1
Donβt forget the valve retainers ππlooking good Lol, just been to the shed for the m5 Allen bolts New retainers ready to fit π Steve
Post by midlifecrisisrd on Aug 6, 2020 20:20:39 GMT 1
Just so Matt can sleep π
Post by Yogi on Aug 6, 2020 20:29:38 GMT 1
I can sleep well in my static van tonight now π΄π΄π΄
Post by midlifecrisisrd on Aug 11, 2020 20:43:14 GMT 1
NOS pistons and rings in, gen base gaskets and barrels on Steve
Post by midlifecrisisrd on Aug 12, 2020 12:01:44 GMT 1
Forgot the barrels on pic π
Post by arrdy350 on Aug 12, 2020 12:59:52 GMT 1
Top job  Is it hard to get gen gaskets? Also where did you find NOS pistons and rings?
